Aug 30, 2015 - 5:04 PM
Enthusiast Joined Aug 10, '15 Currently Offline Reputation: 0 (0%) |
So my front drivers side turnbsignal will turn on but when i want it to flash( blink, whatever) it only stays on. This isnt happening to the other side. Also the back drivers blinks faster than the passenger side turn signal. Whats going on? Help would be appreciated.
Aug 30, 2015 - 11:23 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 23, '12 From Warrior, AL Currently Offline Reputation: 0 (0%) |
Sounds like the flasher is bad, it's incorporated into the hazard switch. You could try cleaning contacts first, otherwise it'll need replaced. This is provided you have halogen bulbs, if you're trying to use LED bulbs that brings its own set of issues.
This post has been edited by Box: Aug 30, 2015 - 11:23 PM -------------------- 2001 Miata LS 5-speed
Aug 31, 2015 - 5:49 PM
Sounds like the flasher is bad, it's incorporated into the hazard switch. You could try cleaning contacts first, otherwise it'll need replaced. This is provided you have halogen bulbs, if you're trying to use LED bulbs that brings its own set of issues. It was the oem bulb so i just have to replace the bulb that wont work right? Thank you for repying sir. |
Sep 2, 2015 - 3:08 PM
Enthusiast ![]() ![]() Joined Jul 1, '14 From Hawaii Currently Offline Reputation: 3 (100%) |
Do your hazards work? If so its the flasher, NOT the OEM bulb. The only reason your blinker would stay on, is if the front AND the rear bulbs are out, and the other side has either the front or rear bulb is out causing hyper flash on one side, and a steady signal to the other.
By the first question, I mean to turn your hazards on and see which bulb(s) is(are) out This post has been edited by Noahwhite2014: Sep 2, 2015 - 3:09 PM |
Sep 4, 2015 - 7:33 PM
Also check the bulb sockets for contact issues. My Corolla had a wimpy socket that would sometimes flash fast even if the bulb was good.
Sep 5, 2015 - 1:20 PM
Thank you everyone for your responses. it turned out my contacts were dirty as a mofo haha. went and replaced my front blinkers with some amber bulbs as i am planning on getting the clear lenses sometime soon i hope. also found out my side markers werent even plugged in lol got some ambers for those too as they were burnt out.
| Lo-Fi Version | Time is now: July 30th, 2026 - 8:28 AM |
