> Exhaust Fitment Issues, Coupe/Convertible exhaust on Liftback chassis
post Dec 24, 2015 - 1:27 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
Well no one's bitten at my fujitsubo exhaust(10days now) so I might consider keeping it if I don't sell by end of January. I actually like the sound it produces as I had a friend drive it while I was outside
But how do I prevent the muffler from banging on the crash bar? I can bairly just fit my pinky finger between muffler and crash bar.
Sure I can put some sort of padding, but that will eventually wear down. And removing crash bar will make it unsafe if someone hits me. Should I just chop away at crash bar and then spray primer to prevent rust?
This post has been edited by BonzaiCelica: Dec 24, 2015 - 8:43 PM
post Dec 24, 2015 - 2:45 PM
Try...
Trim the bar a bit with a cut off wheel on a grinder
or
Adjust the hangers
or
Bigger (longer) rubber hangers.
I would trim the bar a bit.
post Dec 24, 2015 - 5:12 PM
BonzaiCelica
Joined Apr 24, '08
Would some polyurethane hangers work?
post Dec 24, 2015 - 5:15 PM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
I have very close clearances with the over axle 3in, only solution that helped was poly hangers.
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Dec 24, 2015 - 8:43 PM
BonzaiCelica
Joined Apr 24, '08
Their we go that's a much better picture
post Dec 25, 2015 - 9:04 AM
4-eyed-freek
Joined Apr 17, '10
I would cut the bar a bit, and use poly hangers for the rear muffler section. My clearance over the sub frame was very similar to that and poly hangers took care of the issue.
post Dec 25, 2015 - 9:09 AM
Sledgehammer.
post Dec 25, 2015 - 1:51 PM
get a coupe. Problem solved
post Dec 25, 2015 - 5:04 PM
BonzaiCelica
Joined Apr 24, '08
Oh yea well like your exhaust is to restrictive for your V6. I mean like geez have some respect for that engine, upgrade to 70mm piping and sell me your exhaust.
You know so you can get ready for your supercharger ahead of time n stuff redface.gif
post Dec 25, 2015 - 7:27 PM
QUOTE (Batman722 @ Dec 25, 2015 - 8:09 AM) *
Sledgehammer.
This is the solution.
Lo-Fi Version Time is now: September 14th, 2026 - 9:57 PM
