> st205 intercooler on st185, any mods?
post Feb 19, 2004 - 7:12 PM
celicakid84
From New Jersey
I know you can fit a st205 or st185 w/a intercooler on a st185 3sgte but does it require any modification. I would like to use the st205 hood, but i know this isnt suited for the 2nd gen tmic bc it doesnt force air over the tmic like the alltrac hood. Anyways, will the st205 w/a intercooler fit on the 2nd gen 3sgte without any modifications?
post Feb 19, 2004 - 7:18 PM
Yeah it does you gotta get the water pump and tap into the radiator fluid or use a seperate resovoir.
post Feb 20, 2004 - 4:11 PM
qatar11
From Lake Orion, MI
QUOTE (Supersprynt @ Feb 19, 2004 - 5:18 PM)
I disagree,
You will need to run a seperate cooling system to cool the air charge
To run the ST205 W/A intercooler you need the following
Intercooler
Water Pump
Heat Exchanger
Coolant Hoses
W/A Intercooler Computer
and all the wiring, clips, etc etc etc.
i would reccomend a front mount and use water injection which is much easier to control and install.
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Feb 20, 2004 - 6:41 PM
celicakid84
From New Jersey
ok thanks for the help....ill either stick with the st185 tmic an get a hood scoop or go front mount
Lo-Fi Version Time is now: September 12th, 2026 - 8:04 PM
