> OEM-ish, Trying to find complete kits
post Nov 16, 2016 - 12:40 PM
dietcam
Joined Nov 24, '15
From Wauconda, IL
So, it's about that time. I'm trying to find complete strut kits. I'd like to go Monroe, like Scotty Kilmer from Youtube, but I cant seem to find any actual online places to purchase them. If anyone can post links to OEM or OEM-replacement complete kits, that'd be great. I need all 4... so... yeah. Ive got a '94 AT200 Hatch if that makes a difference. I would get the $630 CX racing coilovers from ebay, but I dont want to change the ride height or spring rates, I just want stock.
- Diet
post Nov 16, 2016 - 1:58 PM
Box
Joined Feb 23, '12
From Warrior, AL
Here's RockAuto: https://www.rockauto.com/en/catalog/toyota,...sion,strut,7584
Checked Amazon and eBay with part numbers and seems RA is least for a full set, plus can Google for the 5% discount code too.
2001 Miata LS 5-speed
post Nov 16, 2016 - 2:11 PM
dietcam
Joined Nov 24, '15
From Wauconda, IL
QUOTE (Box @ Nov 16, 2016 - 1:58 PM) *
I was looking for something that's complete. Like quick-struts.
- Diet
post Nov 16, 2016 - 2:23 PM
richee3
Joined Jun 29, '08
From Denver
Nobody makes them for our cars that I've ever seen. Unfortunately everything will need to be ordered individually.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 16, 2016 - 9:23 PM
dietcam
Joined Nov 24, '15
From Wauconda, IL
Would I be making a mistake if I got these?
http://www.ebay.com/itm/142109860751
- Diet
post Nov 16, 2016 - 11:34 PM
richee3
Joined Jun 29, '08
From Denver
Not at all. Many members here on the forum are using Megan Racing coilovers and are very satisfied with them. I don't think they'll be quite as soft as stock suspension but they won't be unbearably stiff either.
1998 Celica GT-
BEAMS Swapped.
post Nov 18, 2016 - 11:32 AM
rich045
Joined Oct 12, '16
From NYC
QUOTE (dietcam @ Nov 16, 2016 - 10:23 PM) *
QUOTE (richee3 @ Nov 17, 2016 - 12:34 AM) *
I actually have the same thing, 94 at200 hatch that got blown struts/shocks, i did buy those megans and they ride smooth on regular roads. On the other hand they ride a bit harsh on rough roads (i have them dialed to 6, you can dial them to 15). Also if you are gonna get those, i suggest getting SPC or eibach (which are the same!!! just price difference) camber bolts (2 sets, this car uses mcphearson front bad back). the part number is SPC81270 or eib5.81270K.
the rear brake lines are gonna be a bit hard to get on since the bolt is located opposite to the way it comes factory, also the clear coat makes screwing the lines a bit tough.
hope that helps!
post Nov 21, 2016 - 12:36 AM
trdproven
Joined Aug 2, '05
From Guam
^ you need to fine adjust your damper for all roads mine drives better than stock on over a 3 inch drop. Takes a while to tune
This post has been edited by trdproven: Nov 21, 2016 - 12:36 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Nov 21, 2016 - 9:21 AM
cheela
Joined Feb 2, '07
From Berlin, WI
i can vouch for the megan ez's as well. worth the money if you're looking to upgrade. ride is comfortable enough that it won't kill your back or anything.
if you're changing out the struts then I would suggest replacing your end links at the same time as it can be a bitch to remove them. I ended up cutting mine and just upgrading to thicker sportier ones. if you don't want sporty then there are OEM equivalent ones that are better designed as well.
post Nov 22, 2016 - 12:03 PM
rich045
Joined Oct 12, '16
From NYC
QUOTE (trdproven @ Nov 21, 2016 - 1:36 AM) *
You obviously dont know about new york city streets LOL
yea the roads are bad, always construction, always a pothole, or a manhole, or some sort of crater
QUOTE (cheela @ Nov 21, 2016 - 10:21 AM) *
you are 100% right, i had to cut one end link cause it was frozen.
so far i got like 2 week on them, waiting for them to settle so i can dial in the suspension correctly.
Lo-Fi Version Time is now: August 23rd, 2026 - 6:27 PM
