Closed TopicStart new topic
> FS: 4th gen 3sgte Celica GT Convertible
post Feb 2, 2017 - 12:08 PM
HardHead93
Joined Apr 7, '15
From New Mexico
1997 Celica GT 3sgte, $7500
This is a 1997 Toyota Celica GT Convertible with a 4th generation 3sgte swap. The car has 143,700 miles on the chassis and less than 60,000 miles on the motor. This motor was freshly swapped (completed in Jan 2017) and has only been driven approximately 1000 miles since the swap. The 3sgte comes out of a 1998-2002 JDM Toyota Caldina. Since the new engine is an unmodified and fully inspected OEM motor with the stock ECU it will maintain the reliability that Toyota is so well known for. It is advertised that this motor on 12 psi of boost produces 256 horsepower with boosting kicking in as low as 2200 rpm. This engine has the potential for more power with a boost controller and the proper supporting mods.
The car also benefits from the stiffer chassis due to the factory reinforcements in place because of it being a convertible. There is little to no body rust due to spending all of its life in the dry warm weather of California, Arizona, and New Mexico. The car has been garaged from when I purchased it in 2012 to now. All the amenities (AC, heat, power windows, etc.) on the car are in working order. The interior is stock and there is a small tear in the front driver side seat. To buy and build a car like this in today’s market (if you can find a clean chassis) would cost in the neighborhood of $12-15K. See all features and modifications below. The title is clean. The buyer must arrange their own pick up. Here is a link to a video of the car: https://youtu.be/dO9D_1jgr7U The reason I am selling is because I plan to get a RWD car.
Engine:
4th Generation 3sgte with wiring done by Wiregap
Red Powder Coated Valve Cover
Mushroom Filter 3 inch Intake
3 inch PrimeMR2 downpipe
SSQV Style Blow-Off Valve
Front Mount Intercooler
2.5 inch intercooler piping
Walbro 255lph Fuel Pump
MR2 Limited Slip Differential (installed by local transmission shop)
S54 Transmission (recently inspected by a local reputable shop)
Under Hood Air Dam
Stage 2 SPEC Clutch
XTR Lightweight Flywheel
2.5 inch Magnaflow custom full exhaust
K-Sport Sealed Oil Catch Can
Front and Rear Polyurethane Motor Mounts
Optima Red Top Battery
2 row aluminum radiator
Suspension:
KYB Excel-G Struts
Ground Control Coil overs with Eibach Springs
Upgraded Front 2 Piston Avalon Brake Calipers
Drilled and Slotted Front Disk Brakes
Front Tires are new and rear tires have approximately 5000 miles on them
Interior
Pioneer AVH3700 Touch Screen Radio
Bluetooth Microphone
Glovebox USB connectivity
Glowshift Gauges
Oil Pressure
Water Temp
Air Fuel Ratio
Boost/Vacuum
6.5 inch front and rear Pioneer Speakers
Subwoofer from video not included
Exterior:
Wings West Painted Spoiler
TRD Front and rear lips
TRD Side Skirts (Included but not installed)
VIS Carbon Fiber Hood with vents and scoop
Carbon Fiber Bumper duct
20% Window Tint
This post has been edited by HardHead93: Feb 4, 2017 - 2:33 AM
post Feb 13, 2017 - 8:36 PM
HardHead93
Joined Apr 7, '15
From New Mexico
No longer selling, please remove this thread.
Lo-Fi Version Time is now: August 23rd, 2026 - 11:37 PM
