> Started painting my dash and console..., Pics.....
post Mar 10, 2004 - 10:04 PM
DmVinny
Joined Feb 23, '03
From Florida
Started painting my dash... heres some progress pic's...
Click here
Still gotta finish the shifter area, more of the door panels, and the passenger side airbag area.
This post has been edited by DmVinny: Mar 10, 2004 - 10:04 PM
Replies (1 - 10)
post Mar 10, 2004 - 10:06 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
Looking good....
FlickR
post Mar 10, 2004 - 10:57 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
pimptastic
post Mar 10, 2004 - 11:14 PM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
looks really good!
post Mar 11, 2004 - 12:13 AM
Crzybakerdog
Joined Apr 18, '03
From milwaukee, wisconsin
what kinda sprays did you use for painting them? i want to do that color as well for the summer, also how hard was it /suggestion for getting all the peices that you got out?
post Mar 11, 2004 - 1:02 AM
good effort, but not my style.
post Mar 11, 2004 - 1:11 AM
Cody
Joined Dec 11, '02
From Sioux Falls, SD, USA
Just a question...why do you have 2 stereos?
post Mar 11, 2004 - 1:21 AM
Jabberwock
Joined Sep 22, '03
ones an EQ and the other is a deck...
post Mar 11, 2004 - 1:23 AM
macavely
Joined Nov 4, '02
QUOTE (Cody @ Mar 11, 2004 - 1:11 AM)
one is the head unit the other one is the EQ
and as for the paint color.. some one else had that same color a few years back.. i wonder who that was... wink.gif
post Mar 11, 2004 - 2:18 AM
DmVinny
Joined Feb 23, '03
From Florida
QUOTE (Crzybakerdog @ Mar 10, 2004 - 10:13 PM)
I used Krylon quick dry spray paint (normal paint) and Krylon's quick dry clear coat...
Popping the pieces out where simple, the right a/c duct gave me the most problem but a bit of tugging and shaking got it out.
Painting is quite simple, since this is quick dry it usually takes about 12 minutes to dry... basically i lightly went over the pieces (about 16 inches from each piece) than I let it dry, went back did another coat a bit heavier than the 1st, than of course the next coat a bit heavier. for the 2nd and 3rd coat you want to make sure you get the whole panel covered.
Once this was done, its a rule to sand, but its not necessary as long as you spray right. So I layed a light coat of clear coat almost like a mist. let it dry, than went over the panel thick making sure to evenly coat it (if you have a nice lighted area you can tell by the gloss highlight of the clear coat adhering to your panel). Once this coat dried, I sanded it with 2000 wet/dry, the reason for the 2000 wet dry is to give the last coat a nice deep clean smooth look.
Let it dry a couple of hours, and your ready to go... i normally put a nice coat of wax on it to keep it protected and shiny too.. (although those pics are taken before the waxing, but ill take some more)...
post Mar 11, 2004 - 2:19 AM
DmVinny
Joined Feb 23, '03
From Florida
QUOTE (Cody @ Mar 10, 2004 - 11:11 PM)
Top is the radio: Pioneer Premier DEH-P660
Bottom is the EQ/DSP: Pioneer DEQ-7600
Lo-Fi Version Time is now: May 18th, 2026 - 3:41 AM
