> Box building..., Software?!?!
post Mar 14, 2004 - 10:08 PM
DmVinny
Joined Feb 23, '03
From Florida
Normally when I build a subwoofer box I draw it on paper, but the enclosure I have planned is a bit more complex.. Anyone recommend a good 3d program or similiar...?
I dont need calculators... btw.
Replies (1 - 12)
post Mar 18, 2004 - 1:30 PM
6gcs3nz
Joined Feb 8, '04
From Auckland, New Zealand
Try WinISD by LinearTeam: http://www.linearteam.dk/default.aspx?pageid=winisd
I haven't used it myself but its free and I've heard good things about it.
post Mar 18, 2004 - 2:57 PM
DmVinny
Joined Feb 23, '03
From Florida
I dont think it does 3d images, im leaning more towards the 3dsmax look, since my the idea behind my box is more complicated than a plain square box etc.
post Mar 18, 2004 - 8:07 PM
Yobbe
Joined Mar 12, '04
From Norway
I have made a model of the Celica rear end in 3dsmax just for this purpose. I just need to adjust it so that the measurements are correct and it should be pretty nice for designing boxes. If you have 3dsmax I can send it to you
or
I could help you design it if you have some rough scetches and MSN for instance ?
post Mar 19, 2004 - 4:45 PM
DmVinny
Joined Feb 23, '03
From Florida
Hey man, yeah if you have a nice sketch of the trunk in 3dsmax i'd like to have it
post Mar 19, 2004 - 8:21 PM
Yobbe
Joined Mar 12, '04
From Norway
It just needs to be adjusted so that the measurements coencide with the actual trunk
The objects are more or less precise when it comes to shape, but my celica is in the shop having its top worked on, so i havent been able to take any measurements.
This is a 96 Celica trunk done in 3D Studio Max 5
You can download the file at: http://www.gunstig.org/celica96/celica_trunk.max
I'll post some updates as I get the measurements etc.
This post has been edited by Yobbe: Mar 19, 2004 - 8:22 PM
post Mar 19, 2004 - 11:24 PM
MoralWarfare
Joined Feb 12, '04
From Hellburbia
can't view without 3dsmax
post Mar 19, 2004 - 11:41 PM
Stipt
Joined Apr 29, '03
From Davenport, IA
autocad? Would that be easier? or more precise?
post Mar 20, 2004 - 10:17 AM
DmVinny
Joined Feb 23, '03
From Florida
Yobbe I have the trunk measurements... Ill add em in... and convert the 3dsmax file for others to view as well
btw thanks.
This post has been edited by DmVinny: Mar 20, 2004 - 10:17 AM
post Mar 20, 2004 - 10:27 AM
DmVinny
Joined Feb 23, '03
From Florida
Here it is in autocad;
http://home.comcast.net/~dmvinny/celica_trunk.DWG
post Mar 20, 2004 - 11:10 AM
boosted_K2
Joined Aug 30, '02
From Michigan
autocad blows. solid edge has a bit of a learning curve but its pretty good.
No but I don't buy it
Cause I'm...
post Mar 20, 2004 - 7:20 PM
Yobbe
Joined Mar 12, '04
From Norway
Just posted it in MAX format since that was what was mentioned earlier in the post smile.gif
post Mar 21, 2004 - 2:35 AM
DmVinny
Joined Feb 23, '03
From Florida
Didnt add the measurements yet Yobbe, but I will.. btw, u seem good with 3dsmax maybe u can help me wif it since im sorta new to 3dsmax and designing what I want.
Lo-Fi Version Time is now: August 22nd, 2026 - 9:26 AM
