> removed cat
post Mar 25, 2004 - 3:05 PM
kuruptedsnake
Joined Jun 13, '03
From brooksville,fl
if i remove my cat will this trigger the check engine light to come on and if so can i reposition the 02 sensor so that it does not go on
Replies (1 - 19)
post Mar 25, 2004 - 5:08 PM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
post Mar 25, 2004 - 8:28 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
nothing major... my toyo dealer knocked out mine
post Mar 25, 2004 - 10:36 PM
kuruptedsnake
Joined Jun 13, '03
From brooksville,fl
wait isnt it illegal for them to do that? i just want to know if my check engine light will come on. and what will i have to do about that 02 sensor thats connected to it
post Mar 26, 2004 - 11:51 AM
96stcoupe
Joined Nov 3, '03
From Iowa
Since your vehicle has obd 2 the check engine light will most likely go on. It did on my 96 anyway. It will set a code for the catalyst being inefficient or something like that. Damn downstream o2 sensor.
post Mar 26, 2004 - 1:30 PM
FallenHero
Joined Dec 26, '02
From Alabama
the 94-95 version don't have that do they? Also, your exhaust will smell like a rotten egg.
post Mar 26, 2004 - 1:55 PM
subsolo_21
Joined Nov 26, '03
From McKenzie, TN
damn, i was gonna gut my cat, but i forgot about the smell. oh well i took out my resonator yesterday and replaced it w/ straight pipe and got a high flow muffler. I guess that good enough for now. Any ideas on what else i can do?
post Mar 26, 2004 - 1:57 PM
shid
Joined Jan 8, '04
From LA
A hi flow cat? Do they actually work?
post Mar 26, 2004 - 2:35 PM
subsolo_21
Joined Nov 26, '03
From McKenzie, TN
From what I have read a hi flow cat, despite what many claim, only produces 2-3 HP gains. I'd say probably not worth the $, but thats just my opinion. The only reason I wanted to gut my cat was for the extra sound, but it also sacrifices some low-end torque and the only HP gains would be so high in the power band and so small of a gain that it really wouldnt help any, since the celi redline at about 6400 or so.
post Mar 26, 2004 - 2:48 PM
shid
Joined Jan 8, '04
From LA
Well, I don't want the cat stealing 5 hp anymore (roughly) but I don't want my car to smell like **** either. If a new hi flo cat gets me 2-3 hp, I'm all for it.
And it should't have any effect on low end torque unless you get too big of an inlet outlet on your new hi end cat- or you do something wierd when you remove the cat.
I'm interested to know tho, if the hi flo cats smell like ****, or do they smell like a real cat?
post Mar 27, 2004 - 9:40 PM
Stipt
Joined Apr 29, '03
From Davenport, IA
So wait, with no cats your car smells like crap???
post Mar 27, 2004 - 11:00 PM
SpedToe169
From Dallas, Tx
No.
I don't know where everybody gets this. What do you think cars smelled like before the 70s? Cars haven't always had cats. Its like little kids thinking that there was no color back when there was only black and white tv.....
post Mar 27, 2004 - 11:03 PM
Yeah, my car has no cat, and it smells just fine. A bit loud to the point where my interior panels have all rattled loose and I can't talk on a cell phone on the freeway, but no bad smell. biggrin.gif
post Mar 27, 2004 - 11:32 PM
kuruptedsnake
Joined Jun 13, '03
From brooksville,fl
so then what do i do about the check engine light
post Mar 27, 2004 - 11:54 PM
Jaws4God
Joined Mar 27, '04
Has anyone made any modifications to their resonator?
post Mar 28, 2004 - 12:11 AM
PaulGT
Joined Nov 8, '02
From Bel Air, MD, USA
I have a straight pipe from my header back to a muffler...no cat and no resinator...sounds fine and dont smell to bad...noticed a big gain in power too wish my clutch isnt bad so i could still feel the power i felt when i first got it all put on. frown.gif but its still cool.
post Mar 28, 2004 - 12:47 AM
Jaws4God
Joined Mar 27, '04
I know I have to have a catalytic converter, and the Inspection place said I had to have the resonator. But I was hoping to swap it out with a hi flow or something.. Does anyone know of anything like that? Would it add more sound to my exhaust?
This post has been edited by Jaws4God: Mar 28, 2004 - 12:47 AM
post Mar 28, 2004 - 9:10 PM
kuruptedsnake
Joined Jun 13, '03
From brooksville,fl
WHAT ABOUT THE CHECK ENGINE LIGHT!!!!!!!!!!!!!! HOW DO I GET IT TO GO AWAY!!!!!!!!!!!!!!!
post Mar 28, 2004 - 9:19 PM
96stcoupe
Joined Nov 3, '03
From Iowa
I am not sure about how to get the check engine light to not go on but I was thinking that maybe with an intake, and a leaner air fuel mixture the sensor may not read the cat inefficient and set the light. Not sure if that would work though. They make o2 simulators for hi performance cars but not for ours. If you are good with wiring you may be able to get a universal one to work. Good luck.
post Mar 28, 2004 - 11:09 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
It should be fairly simple to get an O2 simulator to work with a Celica, you'd just need an ECU pinout to determine which wire supplies the ECU with signal, and connect the other wires as per the simulator's instructions. (Ones I've seen have at least one power connection and a ground.)
A link that may help...
http://www.mkiv.com/techarticles/oxygen_sensor_simulator/
(DIY instructions, note that the ECU connections in this article will NOT work on a 6g Celica and I take no responsibility for any foolishness.)
Lo-Fi Version Time is now: August 4th, 2026 - 1:16 PM
