Mar 25, 2004 - 7:34 PM
![]() Enthusiast ![]() ![]() Joined Dec 21, '03 From Portland, OR Currently Offline Reputation: 0 (0%) |
where do I run the wires from the main compartment to the engine and the battery? Like where's the hole at that I can squeeze the wire throught?
Mar 25, 2004 - 9:15 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
it is on the passenger side its like a little boot (looks like an old style shift boot for a truck) poke a coat hanger through it and push it down untill you see it come out under you glove box, then fasten the wire to the coat hanger and push it through
Mar 26, 2004 - 5:12 AM
Enthusiast ![]() ![]() ![]() Joined Nov 15, '03 From mississippi Currently Offline Reputation: 0 (0%) |
I would recomend going to your mehcanic and have him drill you a hole on the drivers side.
William |
Mar 26, 2004 - 11:37 AM
Or you can save ur self some time and money and actually drill a hole urself.
Mar 26, 2004 - 11:56 AM
I already have a hole on my drivers side?
Mar 26, 2004 - 12:10 PM
if ya havnt gotten it already, just run it through the rub cover.. Thats were i did mine, heres a pic, then run it right down, you will most likely need to remove your glove box an stuff.. heres a pic to get an idea.
Mar 26, 2004 - 1:24 PM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 12, '03 From Portland , Oregon , United States Currently Offline Reputation: -1 (33%) |
The Use-less Ghetto Install everyone Does.....
![]() The Nice Install I did With hardley any wires showing, and not having anything running near/over the engine. ![]() ![]() DTE -------------------- I am a thief.
do not buy anything from me. |
Mar 26, 2004 - 1:35 PM
clipse if your gonna critisize our techniques you coudl atleast elaborate on yours
Mar 26, 2004 - 1:44 PM
First I ripped out that old install. The Fuse and Most of the wire was destroyed. I picked up 35ft of 4g wire from sounddomain ( here in 2 days nice ). I was gonna run it threw the driver side then figured there wasnt a whole big enough inside ( where the wire come threw the side inside the cab, 8g Might fit tho). So I took off the inner and fender on the passenger side and laid out How I think it should go cut to the right length and started Zip Tieing.
I looped around the battrey with about 9" of wire then mounted a Phenoix gold Fuse. I went under the front crossmember attaching the wire to the exsisting Loom and also zip tieing threw the extra holes. went the rest of the way across the front cross member I twisted the cable a lil bit so looking from the front or straight down couldent see it ( I know im anal ) Into the fender cavatee it went. I continued to attach it to the exsistin loom with zip ties. To get it into the cab you have you have to cut a very very small hole in one of the 2 ruuber groments Strech it to get your wire threw, then I filled it with a slicone sealer then wrapped it up with electric tape. Total time 4-6 hours. DTE -------------------- I am a thief.
Mar 29, 2004 - 10:34 AM
Enthusiast ![]() ![]() Joined Dec 19, '02 From West of Atlanta Currently Offline Reputation: 1 (100%) |
I ran mine from the battery into the fender. Over the wheel well and into the boot behind the fuse/wiring block in the drivers kick panel. Just use some rtv to seal the boot well. Pulling a few of the wheel well clips lets you peal it back for access.
Mar 29, 2004 - 2:56 PM
Enthusiast ![]() ![]() ![]() Joined Feb 23, '03 From Florida Currently Offline Reputation: 0 (0%) |
For a nice install your gonna need these as well...
![]() Battery Terminal ![]() In-Line Wafer Fuse Holder.... ![]() And of course the Wafer Fuse. This post has been edited by DmVinny: Mar 29, 2004 - 2:59 PM |
Apr 2, 2004 - 2:11 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 26, '03 From Wisconsin Currently Offline Reputation: 0 (0%) |
thanks audiofreak, I ran my wires today and its marvelous there. -------------------- i am awesome
Apr 2, 2004 - 11:47 AM
hey i have a question, How many of you run just standard fuses, or a breaker? my min reason is, because any time i screw with my wiring i manage to blow the fuses, juts me being stupid , and trying out dif stuff.... but sence i no longer work at bestbuy and i ran out of them, it dont feel like wasting 5 bucks a pop... so if any one has any idea, please let me know. Thanks
Apr 2, 2004 - 12:01 PM
you can pick up 4 fuse's for a Buck at most car shops.
Apr 2, 2004 - 7:19 PM
Breakers are nice. Let you flip off the power eaisly. But they can go bad... I've seen a few. If you really wanna protect yourself. Put a fuse between the breaker and the battery that rated higher than the breaker. If the breaker works as it should the breaker will pop before the fuse. I'd go atleast 30 amps bigger than the breaker. If the breaker fails and there is a short the fuse still protects the wiring. This post has been edited by AudioFreak: Apr 2, 2004 - 7:22 PM |
| Lo-Fi Version | Time is now: September 13th, 2026 - 7:39 PM |
