> how to know shocks are bad??
post Mar 31, 2004 - 1:51 AM
sonar
Joined Mar 10, '03
From oklahoma
i bought Tein S-tech lowering springs, im now thinking should i change the shocks as well... how do i know if the shocks are bad and need replacement?
Replies (1 - 12)
post Mar 31, 2004 - 11:30 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
I have a 94 and I just replaced mine. They were probably bad for at least a year before I got around to it. I noticed a lot of "body roll" when going around corners. It's much tighter now that I've swapped them. Hell, if you're going to all the trouble to take them apart, I'd just do it anyways, even if you're not sure. KYBs will only cost you around 250 shipped from Tire Rack.
post Mar 31, 2004 - 11:31 AM
ghostdog
From ny to philly
bounce the front or rear of the car up and down. if it keeps bouncing your shocks are bad. if it dampens quickly they are more than likely okay.
post Mar 31, 2004 - 11:42 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
when u take them off look to see if they are leaking or if you compress them and they dont come back up then they are bad.
post Mar 31, 2004 - 12:16 PM
QUOTE (bufferdan @ Mar 31, 2004 - 11:42 AM)
I dont think the avg. man can compress them..? No?
post Mar 31, 2004 - 12:22 PM
LatinKraze
Joined Oct 22, '03
If they are busted they can........i'm just assuming.
post Mar 31, 2004 - 12:30 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
A new strut is kind of hard to compress but it can still be pushed down some by hand... Wore out ones are very easy to press down and they wont come back up.
post Mar 31, 2004 - 4:17 PM
sonar
Joined Mar 10, '03
From oklahoma
hmm... my car didt bounce up and down alot when i go over some bump or uneven road. do they make any sound when they r bad? coz i notice when i go over some "uneven" road surface, it makes some "klok klok" sound from the back...
post Mar 31, 2004 - 4:20 PM
macavely
Joined Nov 4, '02
do the bounce test.. stand net to the tire and pust down it the cause just pops up and doesnt move at all your good.. it it goes up then down again.. time for new struts... do this at each wheel.
post Mar 31, 2004 - 7:15 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
i just replaced my rear struts...i am getting clunking from the rear so i figured i would need new ones because they are stock with 156k. Well, one of the rear ones was totally shot, the other had alittle life left in it. Anyways, i still have some clunking. Im pretty sure its the sway bar bushings. I will get them on this weekend and see.
post Apr 1, 2004 - 11:20 AM
sonar
Joined Mar 10, '03
From oklahoma
what is a sway bar?
post Apr 2, 2004 - 12:24 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
its a rear stablelizer bar..its supports the rear struts and allows the car to handle better
post Apr 3, 2004 - 9:34 PM
mr_dude
Joined Feb 16, '04
From San Diego
Have they been replaced? If not, replace them. If they're not bad now, they'll be bad soon.
When you unscrew the inserts and they bleed all over you, you'll be convinced.
Lo-Fi Version Time is now: September 23rd, 2026 - 7:00 AM
