Apr 7, 2004 - 8:46 AM
![]() Enthusiast ![]() ![]() Joined Jan 22, '04 From WA, Australia Currently Offline Reputation: 1 (100%) |
I know I;'ve had a few posts about this before
Apr 7, 2004 - 9:34 AM
i don't think 2.5" should hurt your power, thats like the line for an N/A car so you should be good i thinks
Apr 7, 2004 - 9:35 AM
okay thanks! does anyone have 2.5" on their celi? (with pics if possible?)
Apr 7, 2004 - 11:06 AM
Well yeah u'll have less back pressure, but thats cuz you have a larger exhaust.
Less back pressure hurts your low end, improves your top end. But your really not going to feel anything in your car. -------------------- |
Apr 7, 2004 - 11:27 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
assuming your SX is the 1.8l 7afe, I wouldn't go any bigger than 2.25 inch. backpressure is one issue, but its also completely pointless unless you are going turbo in the near future.
Apr 7, 2004 - 12:15 PM
I have a 3'' catback.
Stock ST185 exhaust is 2.25'' to give you an idea. -------------------- |
Apr 7, 2004 - 5:35 PM
Enthusiast ![]() ![]() ![]() Joined Aug 29, '02 From Dallas, Tx Currently Offline Reputation: 0 (0%) |
2.5" should be just fine. Almost perfect for an NA celica. I've done lots and lots of research on this. As far as backpressure goes, please read this:
Apr 7, 2004 - 7:11 PM
After reading that- what you're saying is that for cat back, a 2.5" would be better. What if one went the way of the N1 dual, and split it into two smaller pipes?
Would it do what the N1 Dual claims- retain scavenging power but also add on more free flow? and where is this scavenging power most needed? If it's just splitting off after the cat... |
Apr 7, 2004 - 8:30 PM
You're reading a little too much into it (or taking a little too much from it
On a car with one cylinder bank (I4, I6) a single exhaust is always the way to go. On a car with multiple banks, packaging and cylinder firing order usualy dictate that a dual exhaust is better. In the case of the celica the 'best; power (most torque and best driveability, aka, fastest car) will be found with a well designed 4-2-1 header into a single exhaust. An extensive dyno session would be required to find the optimal length and diameter of the exhaust but it will be somewhere in the 2.25-2.75 range for 99% of street cars (our cars).
I think you're thinking about it wrong. Think of the exhaust flow as a single column of moving air. That column of air has inertia. That inertia can create negative pressure behind the moving column. That negative (relative) pressure creates the scavenging effect. There is no 'where' of the scavenging. It happens everywhere in the exhaust. The end goal is to get the exhaust out of the cylinders as quickly as possible (and as completely as possible, some exhaust always remains in the cylinders during each exhaust stroke, the less the better). Its a really hard concept for me to explain. Am I making sense? |
Apr 7, 2004 - 9:19 PM
You are speedtoe, thanks to my HS and college physics classes
Thanks VERY much for the dual vs single exhuast tip- I didn't find it anywhere else on this site (I could just be stupid tho --Sean PS: I know that Bosal 92-95 Camry headers are supposed to fit on my 5S-FE engine.. is this a 4-1 header, a 4-2-1 header? or will it even fit at all? Is it best to have a custom 4-2-1 header made? What should I ask for/look for? THanks |
Apr 8, 2004 - 4:34 AM
i have a 5S-FE, and I;ve read all the above, just making extra sure, a 2.5" should be okay? but like you were saying, does this mean i would get less low end power? |
| Lo-Fi Version | Time is now: August 27th, 2026 - 4:33 PM |
