Apr 18, 2004 - 10:08 PM
Enthusiast ![]() ![]() ![]() Joined Feb 27, '04 From Illinois Currently Offline Reputation: 1 (100%) |
My rear sway bar stabilizer links are loose. I think the bushings are shot. They rattle like you wouldn't believe. Does anyone know where I could go to get replacement ones besides the dealership? They want to charge me $65 a piece.
Thanks alot. Yota -------------------- ![]() |
Apr 18, 2004 - 10:13 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
Im pretty sure autozone carries them.
Apr 18, 2004 - 10:55 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
try doing a search. there was a thread on this exact topic a couple months ago
Apr 19, 2004 - 10:35 AM
Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
I think we concluded before that the links are expensive no matter where you go. But one guy found them cheap somewhere, but we were unsure if they were the right links of not.... If you find an internet site for cheap, let me know. I need them too
Apr 19, 2004 - 10:39 AM
yeah, I think you're right. I paid close to 60 a piece for mine as well |
Apr 19, 2004 - 12:33 PM
when i checked autozone, they wanted 65 a peace too, I made some, that should be a lot stronger then the stock ones, i have an extra set if ya wanna buy them. I think i might even have two.. just let me know, ill tyr an find a pic too
This post has been edited by Digndoug: Apr 19, 2004 - 12:46 PM |
Apr 20, 2004 - 5:26 AM
Enthusiast ![]() ![]() ![]() Joined Sep 27, '02 From UK Currently Offline Reputation: 1 (100%) |
You can get urethane replacement bushings from Fensport, although they are in the UK.
Apr 20, 2004 - 10:40 AM
Well I think I just need to replace the bushings, but I have no idea how to do that since the bolt just spins. I can't clamp down tight enough to get the bolt off. Anyone have any ideas?
Apr 20, 2004 - 11:36 AM
Enthusiast ![]() ![]() ![]() Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
You need an Allen wrench (hex key) to hold the end of the bolt while you turn the wrench, may need to clean out the hole, be sure the hex key goes in as deep as possible, if you strip it, its time to get the Dremel with a cutoff wheel....
Here's the ones I made,,, Sway bar links it,s been almost a year, they are still holding up fine,,,only prob was they cost as much as stock since I ordered metric stainless steel ends...it could be done much cheaper by using 3/8 SAE ends with a shouldered bolt to fit the 10MM hole in the sway bar. Probably an aircraft supply to find the shouldered bolt, thats where I found some. (after spending the money on metric ends) These were for the front, just screwed a male and a female end together after shortening each about 3/8" , the rear could be done with 2 female ends and a short (approx 3") 10MM or 3/8 stud from the parts store, depending on which ends you get,,, This post has been edited by 97GTinKC: Apr 20, 2004 - 11:47 AM |
| Lo-Fi Version | Time is now: August 31st, 2026 - 3:46 AM |
