Apr 29, 2004 - 11:22 AM
Enthusiast ![]() ![]() Joined Mar 31, '03 From BC Currently Offline Reputation: 0 (0%) |
Las week noticed I wasn't getting an air flowing from the driver's side vent, so I pulled the vent out, and made sure it wasn't closed, well after seeing m fingers through the vent, it wasn't, but still no air flow? Normal flow through the two middle vents and the passanger side. Any ideas?
Thanks exx |
Apr 29, 2004 - 7:26 PM
Enthusiast ![]() Joined Dec 1, '02 From Pittsburgh, PA Currently Offline Reputation: 0 (0%) |
Check the vent tube( not sure what the technical name is ) underneath the dash that carries the air from the center console to the driver's side vent. If you remove the underneath dash trim you will see it easily.
Apr 29, 2004 - 8:23 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
hmm, mine always gets air flowin through it, even when i try to close the vent... interesting...
Apr 30, 2004 - 11:27 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 15, '02 From Corona & Vallejo, CA Currently Offline Reputation: 0 (0%) |
That's most likely his problem. A shop that replaced my heater core, knocked mine off, which is why I'm not getting any air from the driver's side vent either. I need to buy that foam adhesive... or whatever it is that they use, so that I can reattach it. But yes, I have a feeling that this is what's causing the problem. |
May 2, 2004 - 11:13 PM
You guys were totally correct, lay underneath the dash, saw with a flashlight the connection was open, pulled it over the foam, and had the air flowing again. Thanks, probably saved me a few dollars in a service bill.
| Lo-Fi Version | Time is now: August 25th, 2026 - 3:08 PM |
