Apr 29, 2004 - 5:51 PM
Enthusiast ![]() Joined Dec 7, '03 From CANADA Currently Offline Reputation: 0 (0%) |
Hey guys,
I am going to be putting an amp in my car that is 800W MAX. My current setup will probably be 200x2 (2 OHM ) + 200x1 (4ohm) RMS. What gauge power wire should I use? 4 or 8? and what thickness speaker wire should i use? Thanks guys! |
Apr 29, 2004 - 7:34 PM
i would do 4
Apr 29, 2004 - 9:51 PM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 12, '03 From Portland , Oregon , United States Currently Offline Reputation: -1 (33%) |
4g power, and hopefully your Amp can take it, or Disto down to 8g, I would Run 8g from your amp to your subs, alot more power.
DTE -------------------- I am a thief.
do not buy anything from me. |
Apr 30, 2004 - 2:23 AM
damn it people don't listen to Clipset Clipset..that guy is full of BS... lol.. na i'm just kidding ... go with some 4g and some gold connectors for the power cable 8g for the wires.. i usally use 12g or 16g from RS.. -------------------- |
Apr 30, 2004 - 3:48 AM
8g good for the power and ground. Mabey it was just me, but I had 18g from my amp to my subs ( just to get em going ), then switch to 8g and could tell a difference. On my new Celi, I ran 10g for Amp Lead, Power and ground, but its only one amp, then 8g from amp to subs.
Apr 30, 2004 - 7:58 AM
Enthusiast ![]() ![]() Joined Dec 19, '02 From West of Atlanta Currently Offline Reputation: 1 (100%) |
Recommended Power and Ground Cable Sizes
You may be able to get away with 8ga but if you plan on ever adding another amp run 4 ga. Then you'll be all set for the upgrade. knukonceptz.com I've had good luck with these guys. The wire is top notch at a really fair price. |
Apr 30, 2004 - 8:29 AM
Enthusiast ![]() ![]() ![]() Joined Apr 4, '04 From VA, USA Currently Offline Reputation: 0 (0%) |
thats a pretty small amp....if u buy 4AUG wire then it prob wont even fit in the power slot and ur gonna have to cut ur wires newayz....go for 8AUG
Apr 30, 2004 - 11:49 AM
Enthusiast ![]() Joined Apr 1, '04 From Iowa Currently Offline Reputation: 0 (0%) |
You will NOT have an audible difference with 400w between 8 and 4 gauge. It is nice to have 4ga. for a bigger install in the future though.
Apr 30, 2004 - 3:20 PM
Thanks for the info guys! Lets assume that I am not going to be adding anymore amps then I should technically be ok with 8G and assuming that I use 8G and its not enough in terms of power handling, what will happen? Blow fuse or "fire" wire
May 1, 2004 - 10:29 AM
8ga should be fine. Just use the right size fuse and make sure it's as close to the battery as possible. (Less than 18"). The fuse is there to protect the wiring not the amp. The reason to keep it close to the battery is in the event of an accident if the battery moves or the wire is cut there will be less chance of dead shorting the battery. |
May 2, 2004 - 10:10 PM
Or catching the car on fire |
May 3, 2004 - 12:20 PM
![]() Enthusiast ![]() ![]() Joined Feb 26, '04 From SoCal Currently Offline Reputation: 0 (0%) |
I would use an 4G. I have 3 amps in my car with a 4G going to a monster spiltter with an output of 8G to the 3 Amps. Also, its a really good idea to have seperate fuzes for all the amps in your car. Saves you alot of money in the long run
This post has been edited by DaMnItLeWiS: May 3, 2004 - 12:21 PM -------------------- ![]() 95 Celica ST 95 Supra NA |
| Lo-Fi Version | Time is now: August 26th, 2026 - 7:37 AM |
