> Dont know what the problem is.
post Feb 12, 2003 - 10:58 PM
hioctane
Joined Nov 26, '02
I was driving down to noobone's house to take some pictures of his celica. I notice lots of weird things about my celica. My 20% tire threads skided alot because it was also raining. I was at a traffic light, and i was at a complete stop, when the light turned green, i stepped on the gas and it felt like I losing control. My steering wheel was moving as if the tires were pointed towards the left side when i had the steering wheel straight to go forward. Just imagine yourself driving and you see a row of steep holes on the concrete and you drove through that row with your celica. It felt like that. My celica was shaking and vibrating.
I was extremely low on gas too. My gas bar indicator was on "E".
The car felt like it was losing control, not only once, but a few times.
What might be the problem????
Could it be the ABS system kicking in??? could someone explain how the abs works????
Could having very low gas be the problem???????
Could it be my shocks?????
Could it be my power steering???
Could it be lack of tire thread??????
Could it be the alignment of the car???
Replies (1 - 12)
post Feb 12, 2003 - 11:07 PM
slowceli
Joined Oct 31, '02
From grants pass oregon
i would say the tires. but you might check your fluid level for the power steering. as far as abs cant tell you i dont have it. also i would check your struts and make sure theyre not blown. and i dont think being low on gas would cause this
post Feb 12, 2003 - 11:35 PM
hioctane
Joined Nov 26, '02
I am scared. I hope my celica doesn't get me killed........ I hope the air bags deploy. My friend, noobone's airbags didn't deploy at all. frown.gif frown.gif frown.gif
I want to fix this problem. It is now 7:40 in california, im going out to fuel up my gas tank.
This post has been edited by hioctane: Feb 12, 2003 - 11:37 PM
post Feb 12, 2003 - 11:39 PM
slowceli
Joined Oct 31, '02
i rearend some chick doing like 30mph and my air bags never came out either. i even had them checked by a toyota dealer said they were fine. scary. hope you get it fixed before something does happen
post Feb 12, 2003 - 11:43 PM
hioctane
Joined Nov 26, '02
ill take the postive cable out of the battery once i fill up my gas tank and take it for another test drive.
post Feb 12, 2003 - 11:56 PM
FallenHero
Joined Dec 26, '02
From Alabama
Does it feel like you are punching and letting off of the gas really fast, Like BamBamBam. Know what I mean?>
post Feb 13, 2003 - 12:30 AM
hioctane
Joined Nov 26, '02
hey burning. How do I unplug my car alarm????
When i was about to take off the positive cable out of the car battery, the alarm went off and it was extremely loud, It scared the **** out of me.
post Feb 13, 2003 - 12:38 AM
94celicaguy
Joined Nov 11, '02
most likely your tires. i had the same thing happen to me the other day when it was raining.
post Feb 13, 2003 - 1:45 AM
No0bOne
Joined Jan 5, '03
From Bay Area
When your car is low on gas there won't be any problems but the problem is when you're totally emtpy on gas is when your car kind of boggles a little bit than it won'te move anymore. The way FallenHero described is pretty much it. happend to me once..haha
burningcelica, his struts aren't blown yet. when a strut is blown then the car looks lowered. am i correct?
When i was in hioctanes car it felt like his front wheels are going different directions on each side. Also, is it safe to hold in the brake peddle and step on the gas? If so could that be done to test if his tires need to be replaced if it spins?
post Feb 13, 2003 - 2:53 AM
slowceli
Joined Oct 31, '02
when a strut blows it wont always look lower because the spring is what controls your hieght. the strut is just a damper just like a shock. if the strut is blown you will be able to see oil around the strut. if the fornt wheels are going in diffrent directions then you got a serious problem.
ex. blown rack and pinion
broken tie rod- if this was the case though you wouldnt be able to even drive the car
post Feb 13, 2003 - 3:11 AM
macavely
Joined Nov 4, '02
Hey octan your problem is a very simple one to fix get new tires. some thing happened to me just get new tires.
post Feb 13, 2003 - 12:17 PM
Celica95
Joined Sep 4, '02
From Meridian, MS
If you punched on the gas pretty hard from the stop light while raining and your tread is low, your tires are going to feel like that. They are not gripping there road, therefore going from side to side causing the whole car to shake. This would be my guess, it doesnt sound very seriuos to me. If it was a blown rack and pinion or broken tie rod you'd know it by the sound it makes when attempting to drive it.
post Feb 13, 2003 - 3:37 PM
GTS_Bun
Joined Oct 21, '02
From Toronto, Canada
Most probably is your tires slipping on 1st gear. Just ease up on the gas when starting. You people in california don't know how to drive in rain or snow redface.gif
But the 6th celica is a very predictable car in snow. For winter fun, I would corner quickly on snow (in quiet streets), the car will slide, and I'd have to steer to get the car straight again. But yet , the car feels very in control.
Lo-Fi Version Time is now: August 2nd, 2026 - 12:31 PM
