May 19, 2004 - 3:06 PM
Enthusiast Joined Apr 28, '04 From CALIFORNIA Currently Offline Reputation: 0 (0%) |
i was thinking and getting ready to rebuild my 7afe engine....i dont know of any sites or such for RODS or PISTONS....i was asking for some help and options...
to re-build..... PISTONS?? CAMS??? RODS??? anything or help would be great.....thanks |
May 19, 2004 - 3:10 PM
Enthusiast Joined Mar 3, '04 From Las Vegas Currently Offline Reputation: 0 (0%) |
arias makes pistons, i dont know about the other stuff. my mechanic said it would cost about 2k to rebuild the blown usdm 7a i had.
May 19, 2004 - 4:02 PM
Enthusiast ![]() ![]() ![]() Joined Nov 18, '02 From Texas Currently Offline Reputation: 0 (0%) |
Custom is pretty much your only option. The 4agze pistons will fit but that won't do you much good unless you plan to turbo because I believe they'll lower the compression ratio.
May 19, 2004 - 6:46 PM
Enthusiast ![]() ![]() Joined Jul 31, '03 From Panama City Beach, FL Currently Offline Reputation: 1 (100%) |
i thought the made dome pistons for n/a 4a's. anyway, i always go to raceeng.com (or net, i'm not sure). they have a good selection of the top names in engine components. you won't find anything specifically for the 7a but they can make you a set of custom rods to fit some 4a pistons.
May 19, 2004 - 11:24 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
just use the 4a pistons and a 4a Blitz (or hks) .5mm head gasket. that should help out with the compression change. I'm fairly sure the 4a gasket will work. after all, the head itself does.
May 20, 2004 - 2:22 AM
Enthusiast ![]() ![]() Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) |
4afe and 7afe heads are the same... use a 4a-fe head gasket to gain compression, as well as using 4a-fe pistons on a 7a-fe....
if you want a spare head to have built or P&P and not have downtime, i have a 4a-fe head for sale ($50 plus shipping, as is... should be machined and possibly new valves) |
May 20, 2004 - 2:27 AM
WTF a new one is 1600 bucks -------------------- |
May 21, 2004 - 12:00 AM
sad but true. or so I'm told... I really want a spare 7a to work on these days. I took a ride in my friends GST elipse... powerful machine... Anybody in the fl, Ga, Tn area got a spare 7a? |
May 21, 2004 - 11:41 PM
i have everything but the block and two pistons/rods.
May 22, 2004 - 11:37 PM
so you have two pistons\rods and the head right?
| Lo-Fi Version | Time is now: August 27th, 2026 - 7:51 AM |
