> radiator question
post May 26, 2004 - 3:48 AM
celicaracer18
Joined May 23, '04
From Meridian, MS
i the koyo racing radiator worth $312
or should i buy gt radiator for $149 (will this do for the 3sgte swap)
also i think i am getting red of my ac all-together which means i can loose the ac condensor right, and will i be able to use my heater and defrost and fan just not a/c
in its place i was planning on putting an oil cooler and transmission cooler, is this possible
Replies (1 - 13)
post May 26, 2004 - 9:12 AM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
I have no experience with the Koyo rad, sorry.
If you remove the AC completely, the heater and defrost will still work; they are separate systems. Just be sure to block off the hols in the plenum where the refrigerant lines used to go. Also, carry a rag with you if you live in a humid area. I find myself using my AC just about every time it rains just to clear the fog from the inside of my car's windshield.
You should be able to install and oil cooler, no problem. Same with transmission cooler if you will be running an auto trans. Manuals, however don't generally have coolers except on endurance or rally applications, and would take a little fabrication and an electric fluid pump to get working. Imo, best to not worry about it with a 5-speed.
post May 26, 2004 - 9:57 AM
turboinduction
Joined Feb 25, '04
From Wisconsin
radiators are over-rated... you dont need one. Lose your current one and save weight and save the 300 and buy a wing.
This post has been edited by turboinduction: May 26, 2004 - 9:57 AM
post May 26, 2004 - 12:08 PM
Mr7AFE
Joined Jan 28, '03
From underground
celica gt radiator will work just fine for 3s swaps.
use the koyo if you plan on hi boostin... 17 and up as a safety precaution.
imo.. try to keep your ac... you ll need it one day.
This post has been edited by Mr7AFE: May 26, 2004 - 12:11 PM
post May 26, 2004 - 12:20 PM
QUOTE (turboinduction @ May 26, 2004 - 10:57 AM)
W T F?!
post May 26, 2004 - 12:21 PM
QUOTE (Mr7AFE @ May 26, 2004 - 1:08 PM)
Most ppl who have the 3s conversion dont have a/c.
post May 26, 2004 - 12:48 PM
Mr7AFE
Joined Jan 28, '03
From underground
key word " most".
i still have mine.
post May 26, 2004 - 12:53 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
QUOTE (Supersprynt @ May 26, 2004 - 5:20 PM)
W T F?!
i was just messing around...
i wanted to see if anyone would catch that smile.gif Go super
post May 26, 2004 - 6:39 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
i am going to keep all of the a/c stuff just not on my car, if i ever need it i will be able to put it back on in a couple of hours tops
i rarely use ac when i drive now, in my geo the a/c drains 90% of the power biggrin.gif
i do plan on high boosting, very much so in fact, so that means i should get the $312 Koyo frown.gif
does anyone know where i could find a cheaper high performance radiator
perhaps one that will fit in my car but not neccessarily made for it
thanks for all the help by the way
post May 26, 2004 - 6:44 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
Griffon makes a number of aluminum racing radiators for less than $320. I'm sure you could make some brackets to suit the Celica if you can find a radiator with the proper dimensions and with the hose inlet/outlet in roughly the right configuration.
I don't know much about doing so in a modern Celica, but I've fitted one to a '77 GT and it bolted right in, heh.
post May 27, 2004 - 3:33 AM
gas65
Joined Nov 6, '03
From Campbellsville, Ky.
QUOTE (celicaracer18 @ May 26, 2004 - 4:48 AM)
Where did you find a raduator for a GT for that price? I have been looking for one and have'nt found any new under $200.
post May 27, 2004 - 12:31 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
well actually its only 141.95
but here is a link
auto parts onsale
This post has been edited by celicaracer18: May 27, 2004 - 12:31 PM
post May 27, 2004 - 7:39 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
it has free shipping too
post May 27, 2004 - 10:15 PM
gas65
Joined Nov 6, '03
Lo-Fi Version Time is now: August 25th, 2026 - 10:34 AM
