> little help
post Jun 14, 2004 - 7:41 AM
celicaboston1983
Joined Mar 20, '04
hey guys i have a problem getting into gear. well it gets in fine when the first 15 mins after that sometime i cant get into gears any one have any ideas what is wrong?
Replies (1 - 24)
post Jun 14, 2004 - 8:13 AM
o8poa8o
Joined Jun 11, '04
From Wake Forest, NC
QUOTE (celicaboston1983 @ Jun 14, 2004 - 12:41 PM)
What do you mean? Like you have trouble shifting, or the transmition is slipping? Or what?
post Jun 14, 2004 - 8:14 AM
Tweek
Joined May 4, '04
From Panama City Beach, FL
Manual or automatic? I had a prob with a solonoid on an automatic before that did the same thing. Once it got heated up it would'nt change gear, then jumped forward and stalled. Just a thought, I'm no mechanical expert, but I'm sure someone else could give you a better idea.
post Jun 14, 2004 - 8:24 AM
celicaboston1983
Joined Mar 20, '04
manual
celicaboston1983
Joined Mar 20, '04
i cant even get it to gear have to jamn it in sometimes
post Jun 14, 2004 - 8:27 AM
o8poa8o
Joined Jun 11, '04
are you using the clutch, lol... j/k.
you might need a new transmition, but if no1 on here helps much, i'd take it to a mech. and see if you can just get it lub'ed up or if you should get it replaced.
post Jun 14, 2004 - 9:11 AM
boosted_K2
Joined Aug 30, '02
From Michigan
sounds like you may have syncro problems.
No but I don't buy it
Cause I'm...
post Jun 14, 2004 - 9:56 AM
celicaboston1983
Joined Mar 20, '04
how much is to fix synchros?
post Jun 14, 2004 - 10:10 AM
QUOTE (celicaboston1983 @ Jun 14, 2004 - 7:56 AM)
It involves a tranny rebuild I think.
I have the same problem with my C-52 that's mated to my 4A-GE. I'm already running fully synthetic 75W-90 oil in the tranny, but I think I'll try some of that Lucas oil stabilizer. I heard that it works pretty well for a temporary fix.
Do you grind going into reverse as well?
Also, do you ever have trouble getting the car out of reverse once it's engaged?
post Jun 14, 2004 - 10:17 AM
celicaboston1983
Joined Mar 20, '04
some time i do grind in reverse yeah it feels like it stuck half way when im changing it back to first or whatever. Is there any lub or oil that I can use to try to fix it this problem?
post Jun 14, 2004 - 11:07 AM
acenova
Joined Dec 21, '03
From Portland, OR
actually, that same thing was happening to me. Exact same thing! I just took mine to clutch doctors and they simply adjusted the clutch. If it's the same as mine then your shift rod (or something like that) is simply loose and clutch doctors should be able to do it for free, or even if not for free, a minimal charge. But yea, everyone said it might have been my syncros to, but it wasn't. So just take it to clutch doctors man, because I'm pretty sure it's a simple problem and a quick fix.
post Jun 14, 2004 - 11:17 AM
celicaboston1983
Joined Mar 20, '04
clutch doctors? can i just bring it to me mech?
post Jun 14, 2004 - 11:18 AM
celicaboston1983
Joined Mar 20, '04
hey ace when u had it u couldnt get into any gear right
post Jun 14, 2004 - 11:33 AM
Yeah, what is clutch doctors? Is that just a mechanic place that specializes in clutches?
post Jun 14, 2004 - 12:50 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
Well I dont know if its the rod you speak of since it wouldnt explain him having trouble once the engine is heated up but its still something to consider, to me it sounds like some lubrication issues. Go get some high quality synthetic tranny fluid and see if that helps. Im trying to remember the name of some good stuff, might be called syntec synchro mesh or something like that, I believe its a gm product. But alot of people with shifting problems try it and are quite happy with the results.
Also dude, give your tranny a break and try double clutching to get in gear instead of messing up your gears by jamming/grinding it in.
post Jun 14, 2004 - 12:54 PM
celicaboston1983
Joined Mar 20, '04
tried double clutching already step on it 10 tens still wont go in
post Jun 14, 2004 - 1:00 PM
celicaboston1983
Joined Mar 20, '04
i just im gonna try the tranny fluid first btw where do i poor it in
post Jun 14, 2004 - 1:48 PM
QUOTE (celicaboston1983 @ Jun 14, 2004 - 11:00 AM)
First, make sure you can loosen the top drain bolt(You don't wanna drain the fluid only to find that you can't put new stuff in. wink.gif). It's a silver bolt that's 19mm or 22mm I believe...I can't remember, but it's a large diameter bolt with a fairly short head that doesn't stick out too far...I'm almost positive it's the biggest bolt on the side of the tranny that's closest to the front of the car. You then need to remove the drain bolt, which is on the bottom of the tranny, and is the exact same kind of bolt as the filler hole bolt.
Once the oil is drained, put the bottom bolt back in and get it tight, and then fill the tranny with 2.7 quarts of 75w-90 tranny fluid(If you have a ST...not sure on the capacity of the other trannies.) I used BG Synchro Shift III 75w-90 oil in mine, and it didn't do a thing, as far as helping my problems. frown.gif
post Jun 14, 2004 - 1:56 PM
celicaboston1983
Joined Mar 20, '04
damn i have to take off stuff thought it was gonna be like power steering and brake fluids where i just open and poor : (
post Jun 14, 2004 - 1:59 PM
QUOTE (celicaboston1983 @ Jun 14, 2004 - 11:56 AM)
Nope, it's a lot like changing your oil, except the drain bolt is harder to get to.
post Jun 15, 2004 - 9:33 AM
celicaboston1983
Joined Mar 20, '04
brought car to mech clutch is dead : ( theres gones 500 bucks
post Jun 15, 2004 - 10:14 AM
Negative
Joined Apr 28, '04
From Houston, Texas
QUOTE (Coomer @ Jun 14, 2004 - 6:48 PM)
[/QUOTE]
That's the same location as the one on the Geo Prizm's tranny with the 4A-GE. Coomer - This came up last night with the Geo and I need a fill plug - the one on the front you were talking about. What do I call it and where can I get one - Auto parts store or dealership only?
Celica Boston - It's a 22mm BTW. I can find out about the GT in about 5 mins. if you need me to.
post Jun 15, 2004 - 10:21 AM
acenova
Joined Dec 21, '03
From Portland, OR
Man, that sucks. Sorry bro. And for those of you who asked earlier, clutch doctors are mechanics who specialize in clutches and brakes. They have the lowest prices and are the most honest of any of the mechanics I've seen. That's just why I said go there, but I didn't realize they arent in a lot of states. Thought they were more popular than that.
post Jun 15, 2004 - 11:30 AM
QUOTE (Negative @ Jun 15, 2004 - 8:14 AM)
Did it not have the fill bolt in there already? You can probably just go to Toyota and ask them how much it'd be for the tranny oil fill bolt/plug for a C-52 tranny...I bet it's not more than a couple bucks. smile.gif
post Jun 15, 2004 - 1:08 PM
Negative
Joined Apr 28, '04
From Houston, Texas
No it was stripped and the differential leaks around the axels so we have to keep filling it from there. Thanks for the info.
Lo-Fi Version Time is now: August 11th, 2026 - 8:43 PM
