> Amp/Subs question
post Jul 6, 2004 - 7:43 AM
Fingaz
Joined Jun 15, '04
From new york
I've just bought 2 Audiobahn Alum12Q subs. They're 1000RMS each. But idk what kind of amp to buy. I was thinking about buying an Audiobahn A2150HCT 2 Channel High Current Flame Amp. Its a 1200 watt amp. Will this be good or will it be too much power? I wasnt sure because i've been asking some of my friends and they say whatever they think of but i dont think they really know what they're talking about half the time...
thanks for any help
Replies (1 - 14)
post Jul 6, 2004 - 10:23 AM
Because those subs are dual 6 ohm subs, you can wire them to give you a 1.5 ohm load to the amp. That Audiobahn amp puts out 1200 watts RMS at 1 ohm and 600 RMS at 2 ohms, so I'd imagine that you'd be getting approximately 900 watts RMS to your subs, which I think would be plenty. I've heard systems in hatchback Celicas with 185-400 watts RMS that get loud enough to hurt my ears. smile.gif
Also, keep in mind that you may need to upgrade your electrical system via a higher-output alternator or capacitors or something, because 900 watts RMS from an amp will draw a lot of power from the car's electrical system. smile.gif
If you want more power out of a quality amp at a much cheaper cost, I'd look at a JBL BP1200.1. 1,200 watts RMS at 2 ohm and 1 ohm, so you'd get 1,200 watts RMS with a 1.5 ohm load. Also, I'm not sure if Audiobahn over-rates their amps like they do their subs, but I know JBL doesn't over-rate their amps. smile.gif These amps can be found for around $250 I think.
post Jul 6, 2004 - 11:56 AM
shid
Joined Jan 8, '04
From LA
Audiobahn uses the same overrating system for subs and amp- so they'll match. Unfortunetly, that means if he hooks an amo up that ACTUALLY does rated power...
post Jul 6, 2004 - 12:03 PM
Yeah, I'm not so sure if I'd trust those Audiobahns to be running off of even 600 watts RMS per sub, even though they're rated at 1,000 each.
I've found Audiobahn subs to be fairly fragile...I destroyed an Audiobahn 12" sub back when I was first getting into car audio. The sub was rated at 500 watts RMS and I was pushing 300 unclipped, clean watts to it from a JBL amp, but that was enough to damage the sub.
post Jul 6, 2004 - 9:23 PM
CelicaDEATHdie
Joined Apr 1, '04
From Iowa
Whoa whoa........a-bahn amps are UNDER-RATED....you heard me......suprizing huh around 50-100w?? Decent amps......too bad you can't look at them cause you get blinded by the chrome......
edit: I gave my old alum10q 750w and it is 800w RMS......took it just fine. Sealed though....
This post has been edited by CelicaDEATHdie: Jul 6, 2004 - 9:24 PM
post Jul 6, 2004 - 9:25 PM
shid
Joined Jan 8, '04
From LA
.. a-bahn overrates their subs. You can take CelicaDeath's word for it, or you can take coomer and I's; I'm not going to turn this into another a-bahn debate thread.
post Jul 6, 2004 - 10:06 PM
Fingaz
Joined Jun 15, '04
From new york
lol i think i'll take your and coomers word about it.
thanks guys
post Jul 7, 2004 - 2:26 AM
QUOTE (shid @ Jul 6, 2004 - 7:25 PM)
CelicaDEATHdie was just suggesting that their amps were under-rated, which may very well be true...I've just read lots of stories about knowledgable people with good amps blowing Audiobahn subs with less than the subs' rated RMS power.
And I've also heard that Audiobahn amps are far better than their subs, so maybe they are under-rated...tomorrow I'll do some more research, just because I'm curious now. smile.gif
post Jul 7, 2004 - 3:13 AM
shid
Joined Jan 8, '04
From LA
Coomer and Fingaz, I didn't meant to lesson CelicaDeath's statement at all;
basically what you come down to is personal opinion and person expierence- and no one's is really more valid than anyone elses- thats what I meant Fingaz, not that DelicaDEATH didn't know what he was talking about.
post Jul 7, 2004 - 12:38 PM
Fingaz
Joined Jun 15, '04
From new york
Shid i knew what you were sayin. I just dont know much about car audio at all. im only 16 and this is my first car, first system, first everything. I've heard audiobahn stuff before and i really liked the way it sounded compared to sony, and rockfords, and pioneers. I've never heard JL but everybodys says good stuff about em. I think i wanna stick with audiobahn tho.
One more thing.....im pretty much sure im gonna need some capacitors but idk how many to put in. I dont really know how it works but dont you have to use like a 1/2 farad for every 500w?
post Jul 7, 2004 - 12:58 PM
QUOTE (Fingaz @ Jul 7, 2004 - 10:38 AM)
If you haven't bought the subs yet, there are much better values for the money.
I'm not a fan of Rockford or Sony(I had my second Sony Xplod deck explode in the last year last night...at least it was free. mad.gif) I like Pioneer's CD players and speakers and subs, and JL's is nice too, but the main reason why I usually don't have JL stuff is because it's so expensive. I got my 10w6 for $30 though, so I'm happy. smile.gif
There are tons of other great brands out there as well. If you want, you can tell us what kind of music you listen to and whether you prefer SQ(sound quality, how tight and clean the bass is) or SPL(all out loudness), and what exactly you're looking to do, and then we can guide you further. smile.gif
Most of the car audio people that I talk to who really have amazing systems don't actually recommend caps at all. Instead, they recommend deep cycle batteries and higher-output alternators. smile.gif
post Jul 7, 2004 - 1:24 PM
shid
Joined Jan 8, '04
From LA
Its true, caps hide the problem and can cause you to run into big problems later down the line- IE, you dont realize your pumping that much power because the cap hides it. IF, after a high output alternater and say, an Optima yellow top battery, a hyper voltage system and a grounding kit, you still get headlight dim, THEN start addings caps. Cus at that point you've doen everything you could.
PS: coom, I hate you; I was estatic to get my 10w3s are 140$
post Jul 7, 2004 - 1:54 PM
CelicaDEATHdie
Joined Apr 1, '04
From Iowa
I never said A-bahns subs are under-rated........their subs are VERY over-rated.....my old alumQ was fine with 400w when I first got it. A-bahn rates their RMS on their subs in very small enclosures. Cut RMS in half on all a-bahn subs.
post Jul 7, 2004 - 2:12 PM
shid
Joined Jan 8, '04
From LA
QUOTE (CelicaDEATHdie @ Jul 7, 2004 - 2:23 AM)
But its ok, I still love you *hug*
post Jul 7, 2004 - 3:03 PM
CelicaDEATHdie
Joined Apr 1, '04
From Iowa
Lo-Fi Version Time is now: August 24th, 2026 - 1:34 PM
