Jul 9, 2004 - 1:51 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
hey guys
there is a 1998 celica that has athe 3sgte in it for sale in my area PM me for contact info, i will probably go and check it out friday or something like that so i can let prospective buyers on here know some details. This post has been edited by Coomer: Jul 9, 2004 - 10:10 AM -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Jul 9, 2004 - 8:59 AM
![]() Enthusiast ![]() ![]() Joined Sep 4, '02 From South Carolina Currently Offline Reputation: 0 (0%) |
hey man, definately please update us on it, i'm interested...but not enough to contact them myself
Jul 9, 2004 - 10:15 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '03 From Appleton,WI Currently Offline Reputation: 0 (0%) |
if u dont buy it..at least u could take pics
-------------------- ![]() A Jaws4God Creation... |
Jul 9, 2004 - 1:58 PM
Enthusiast ![]() Joined Nov 12, '03 From h town Currently Offline Reputation: 0 (0%) |
verry intrested please post more info asap
Jul 11, 2004 - 2:24 AM
hey guys
i got a bunch of pics of the car http://www.imagestation.com/album/?id=4286...tulation_page=Y the interior is clean, the exterior has some dings and some small roblems with paint, expecially around the hood scoop. i'd say its a perfect 20ft car, any closer and you notice the small things 1991 st185 engine under 66k miles on the clock, less miles on the engine did the swap 2 years ago new rear main seal new plugs, 1.5 year old stage 1 clutch stock 5sfe tranny(needs fluid change) 2 inch exhaust factory DP with cat intact turbo timer boost gauge short ram intake setup greddy type s BOV factory TMIC new timing belt new accessory belts has AC TRD oil cap new battery 3sgte ignitor no CEL pretty clean looking swap engine problems does not have cold start mode engine shakes slightly, possible vacuum leak(although boost gauge does not show it) or maybe the cap and rotor need to be replaced(owner did not say if they were new) the shaking can not be felt in the car, and idles steady at 900rpm. while the shaking could be due to ignition, i have a feeling its because of the vacuum setup, it looks like there were only 3 vacuum lines comming from behind the throttle body, one for the boost gauge, one for the brake booster, and one that went somewhere. there might be a leak that allows unmetered air into the system like the plumbing for the wastegate actuator could also be bad motor mounts, i only checked one and it looked ok from what i saw. or even a small exhaust leak(im guessing all this because i had the same shake in my celica when it was turboed and each time it developed it was either vacuum or exhaust leak, lol) one other problem. the car boosts erradically from what i know of the boost of a st185 engine i believe it should boost 8psi or so in pretty much every gear. but in first it hits 12psi, 2nd 10psi, and 3rd only 5psi. car revved freely and made no strange noises, it was too hot to check the turbo for shaft play but im pretty sure its good. non engine features leather interior floor mats aluminum trim kit silver and black shift boot(matches aluminum trim) side skirts sunroof new head unit new tweeters new speakers sub i have seen this guy driving the car around my city several times. from what i saw, he drove the car sanely -------------------- 1994 Celica GT4 WRC Edition
Jul 11, 2004 - 5:36 AM
I JUST WANT THE ENGINE AND EVERYTHING WITH THE ENGINE
Jul 11, 2004 - 10:07 AM
Enthusiast ![]() Joined Aug 1, '03 From Holland, MI Currently Offline Reputation: 0 (0%) |
how much does he want to get for it?
Jul 11, 2004 - 1:06 PM
i dont think he is going to sell the engine set he is asking for $11,000 -------------------- 1994 Celica GT4 WRC Edition
Jul 11, 2004 - 4:36 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) |
sweet, i would have rather had teks celi than this one though...
| Lo-Fi Version | Time is now: August 25th, 2026 - 8:03 AM |
