> Saw these Rotors, Are they a good deal?
post Jul 20, 2004 - 1:15 PM
coustoe
Joined Sep 18, '02
From Northern, Virginia
saw these on ebay free shipping too
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33564
I searched the forums and people were paying $250 before, seems like a good deal, anyone buy these?
Replies (1 - 20)
post Jul 20, 2004 - 2:08 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
Speedtoe bought a pair off ebay for 85-100 bucks. He says they are great and has had no problems with them. I'd look in to those first
post Jul 20, 2004 - 2:09 PM
coustoe
Joined Sep 18, '02
ya these are $189 for a set of four. seems like a fair price.
post Jul 20, 2004 - 3:11 PM
Negative
Joined Apr 28, '04
From Houston, Texas
What's the name for the ones speedtoe got? I'm looking for rotors now.
post Jul 20, 2004 - 4:45 PM
Puchi
Joined Jul 9, '04
From Annapolis, MD
I got brembo OEM replacements (front) for $52 off of www.tirerack.com I like to stay away from e-bay on parts that are necessary to keep me from rear-ending the guy in front of me.
Pistons are for sissies!
90 RX-7 TurboII
post Jul 20, 2004 - 5:40 PM
fastgt
Joined Feb 13, '03
From California
look for the seller oc_autosports....great rotors great seller his number is
7146589616 tell him juan sent you....rotors are awesome
2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3
gone but not forgotten
2008 Space Grey BMW Z4 ///M
post Jul 20, 2004 - 5:58 PM
remjay
Joined Nov 13, '02
pointless for them to be cross-drilled AND slotted....
post Jul 20, 2004 - 6:15 PM
PhillyGuy086
Joined Sep 18, '03
From Dirty Jersey
well actually the cross drill will help it vent heat off better and the slots will help them shead moisture better...
post Jul 20, 2004 - 10:33 PM
Junior
Joined May 5, '03
From Toronto
crossdrilled and slotted rotor will really eat away at your pads. I would get either cross drilled or slotted, not both
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
I heard that some cross drilled rotors crack very easily?
post Jul 20, 2004 - 10:54 PM
fastgt
Joined Feb 13, '03
From California
my pads havent been eatin and my rotors havent cracked
post Jul 20, 2004 - 11:46 PM
o8poa8o
Joined Jun 11, '04
From Wake Forest, NC
my friend bought some slotted/drilled rotors and supposed "racing" pads off ebay awhile ago, and he said there more sensitive and haven't had any problems though
his are for a prelude tho
This post has been edited by o8poa8o: Jul 20, 2004 - 11:46 PM
post Jul 21, 2004 - 6:56 AM
i got drilled & slotted ones from ebay, irotors was the company, there identical to those youve got there, zinc coated and all, the work good, even with the super crappy pads i have on now, no problems with extra wear, or cracking..the zinc coating works good on the hats too, had them over winter and all, still not rusty! wink.gif
post Jul 21, 2004 - 7:34 AM
98celica3
Joined Aug 30, '02
From North Carolina
QUOTE (bojangles_8686 @ Jul 20, 2004 - 8:33 PM)
drilled rotors can crack under extreme usage. if you are autocrossing, or just driving them really hard for an extended period of time they can become super hot and might crack. under normal driving conditions though they should be fine.
adam
MISS THE CELI, BUT...
post Jul 21, 2004 - 6:29 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
i got irotors. they're great and they're not rough on the wallet. i would call them directly, they give you a better price
This post has been edited by Jdog1385: Jul 21, 2004 - 6:29 PM
post Jul 22, 2004 - 10:26 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
btw, i didn't look at the pic, but i know the ones that speedtoe got did not have many drill holes...since he autocrosses he kept it to a low amount(if memory serves me correct)
post Jul 22, 2004 - 12:53 PM
Doge
Joined Dec 2, '02
From Portland, Oregon
"...on average, a six-piston caliper squeezes a rotor with somewhere in the neighborhood of 10,000 pounds of force. Now imagine taking a sharp turn at high speed with that caliper solidly clamped. That's when your rotor will experience flex, which is when cross-drilled rotors tend to crack." -Super Street
This post has been edited by Doge: Jul 22, 2004 - 12:55 PM
post Jul 22, 2004 - 2:20 PM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
http://www.indycarz.com/forums/viewtopic.p...rilled&start=20
Unless you truely know what you're doing with brakes, (and no offense but you may have room to learn if you're searching on ebay) just get brembo OEM's.
Read that link too
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
post Jul 24, 2004 - 7:16 PM
coustoe
Joined Sep 18, '02
thanks for the info guys, where can i get cheap plain rear/front rotors?
post Jul 25, 2004 - 2:16 PM
SlowCelica94
Joined Sep 28, '03
www.tirerack.com
post Jul 28, 2004 - 9:23 PM
remjay
Joined Nov 13, '02
wow..just wow, you guys really need to become informed before spreading such ludacris "knowledge".
Today there is no need for cross drilled rotors. Other than you like the looks enough, there is no performance benefit to using them, unless you are using brake pads made 50 years ago. Slotted rotors were initally concieved since early brake pads gave off gasses when heated from performance driving. Why? Because the gas acted like a lubricant in that it formed a thin layer inbetween the pad and rotor. This, obviously, lowered the coefficient of friction, thus lowering brake efficiency. It worked nicely, however with time came change and now a days brake pads do not suffer from this "gassing"
So basically, these drilled rotors became more of a asthetic piece. No they do not lower temps, actually they might even raise them since the holes remove the effective surface area needed to dissapate the heat. Also, as it has been posted already, the holes increase the stress in the rotor, making cracking more likely. The holes could even act as cheese grater for your pads, slicing/shaving pieces off.
[The exception being motorcycles where the damn rotors look like swiss cheese themselves- but the stress/pad wear issue is still a factor; this is just done for weight savings..nothing else] <-- Its a trade off: longer pad life/lower temps vs weight.
Think about it...how many nascar/f1/etc do you see with drilled rotors?
Slotting is a little different...this can actually have some benefit. The slots can help keep the brakes clean of glaze and whatnot that can lower brake efficiency. However the cuts shouldnt be deep and cut correctly for their to be any tradeoff benefit.
As for going with cheaper ebay rotors...all i am going to say is you get what you pay for. Those cheaper rotors probably started off with mediocre blanks at best..and drilling holes sure isnt going to help. I dont mean to come off as a pompous jerk; Its your car and money do with it as you wish...just dont go spreading false info.
Lo-Fi Version Time is now: August 31st, 2026 - 11:05 PM
