> NEED HELP QUICK, Antifreeze smell? STRONG
post Jul 22, 2004 - 1:02 AM
spunky393
Joined Apr 22, '04
From illinois
Alright, here's what I did.
Sunday, I replaced my plugs (+4), wires, air filter, cap and rotor (i swear the rotor i pulled out had tar and sand on the electrode, haha). And it was fine that night. Yesterday, it was time to change the oil, so i put fully synthetic, mobil 15W-50 in the car. My dad, for some reason talked me into buying the 15w because of the damn heat up here, so i did. I left my car running today in my friends driveway, with the air conditioner on full blast. I came back out 10 minutes later, open my door, and i swore some clown sprayed me in the face with anti-freeze. So i turned the air off, and drove to macomb later this night (hour and 15 minutes), and the whole way, even with the air completely off (at least the conditioner) i was get small smells of antifreeze.
Anybody, help, quickly
The most important lesson I learned from Karate-Dō Kyōshan“You can not be what you do not believe you are”
Replies (1 - 4)
post Jul 22, 2004 - 7:13 AM
What kinda mix are u running with the coolant?
post Jul 22, 2004 - 12:20 PM
spunky393
Joined Apr 22, '04
From illinois
What ever toyota put in there, when i got the car 8 months ago, i had toyota take everything apart, check it, drain all fluids and replace. Has anybody else used this type of oil though? And a supra i've driven smelled like this because the head gasket was blown, same thing maybe?
post Jul 22, 2004 - 8:01 PM
wht95st-02gtivr6
Joined Jul 20, '04
From naperville il.
if you smell antifreeze in the car it sounds like the heater core is broke/leaking
was the car overheating?
is the coolant level low?
post Jul 22, 2004 - 8:08 PM
spunky393
Joined Apr 22, '04
From illinois
the car wasn't over heating, and still isn't. I'll have to check the coolant level, but i'm pretty darn sure it's fine.
Lo-Fi Version Time is now: August 31st, 2026 - 4:39 AM
