> *Urgent* Celica Back Seat, How to remove 6Gen celica backseat
post Aug 14, 2004 - 4:45 AM
MeEGo0
Joined Jul 8, '04
From Perth, AUS
Hi all, this is kinda urgent. Does any of you guys know how to take the 6th Gen Celica back seat off. I'm trying to run speaker cables but I couldn't take the seat off. Been trying for 1 hour but no luck.
Cheers
Replies (1 - 8)
post Aug 14, 2004 - 5:19 AM
tufy
Joined Dec 3, '03
From Cyprus
i dont have rear seats but... i removed recycle's rear seat once. just pull up from front..
This post has been edited by tufy: Aug 14, 2004 - 5:46 AM
post Aug 14, 2004 - 5:23 AM
MeEGo0
Joined Jul 8, '04
From Perth, AUS
It has some sort of locking mechanism. Tried to pull, but I just couldn't pull it out. Any other suggestions?
post Aug 14, 2004 - 8:54 AM
Andason
Joined Jun 26, '03
From Wisconsin
QUOTE (MeEGo0 @ Aug 14, 2004 - 4:23 AM)
i wrote a how to a while back...
you have to pull out the fold down seats too...
then i think you just pull up on the seats. if not check for a lever under the seat
i am awesome
post Aug 14, 2004 - 9:48 AM
The clips in the front of the back seat just pull out and clip in...the problem ur having is that they're bolted in the back end somehow, i frankly dont kno where I couldnt find where they bolt in.
post Aug 14, 2004 - 10:04 AM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
i didnt have to pull out seats to run wires...
post Aug 14, 2004 - 2:40 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
use a flat head.. then pop it up... should take like less then 30 sec
post Aug 14, 2004 - 3:47 PM
Anub1s
Joined Nov 27, '03
You have to take out the fold down portion of those seats before you can take out the bottom part. Just pull the bottom part up, they can be really stuborn sometimes so just keep pulling, mine didn't want to come out to easily and I had to pull for about 10 mins.
post Aug 14, 2004 - 7:20 PM
ROBWOZ1018
Joined Oct 21, '02
From Pittsburgh
I know cause I had to take off mine to fit a bodykit in my hatch...Fold down the rear seat back and there are two nuts on either side of it attaching it to the trim panel right in front of your strut towers...remove those and the bottom part of your seat will pop right out...to get the whole thing out just take out the bolts under where your seatbelt clamp comes out...I believe there are three...This will remove the top portion as well
Lo-Fi Version Time is now: August 26th, 2026 - 2:55 AM
