> Removing the standard head unit
post Mar 2, 2003 - 9:31 AM
Nickb20
Joined Mar 2, '03
From U.K
Can anyone help me. I want to remove the factory fitted sony double din unit in my celica and replace it with a single unit. I dont know how to get the thing out, any advice would be appreciated confused.gif
Replies (1 - 11)
post Mar 2, 2003 - 10:45 AM
Tony-94
Joined Dec 17, '02
From UK
Ok, what you have to do first is remove the plastic surround from the base of the gear stick - it just un-clips. You can't remove it completely though, just loose.
Then you should be able to see the base of the centre console trim, there are 2 screws that you need to undo.
Now carefully pull the centre console trim panel forward . It is just clipped in place. The vents come off with the panel but stay attached to it.
Watch out for the hazard light and clock which will need unplugging from the console when it is half way out.
With the trim out you will now see the 4? bolts that hold the stereo in place.
This post has been edited by Tony-94: Mar 2, 2003 - 10:46 AM
Facelift bumper-foglights-clear indicators, clear side repeaters, 16in O.Z alloys, stainless steel grill. JDM facelift tail lights. clear sidelights. Retro-fit A/C conversion. APEX performance springs. Remus exhaust. K&N performance filter. KYB excel G shocks.
Hyundai coupe Mk 3 (US Tiburon) leather seats. Gen 7 s/wheel. SR black vinyl door cards. Late spec spoiler-less tailgate with 3rd brake light.
post Mar 2, 2003 - 2:02 PM
Nickb20
Joined Mar 2, '03
From U.K
Thanks, i will give it a go, is it easy to do or do you think i will be better off getting the toyota garage to do it for me smile.gif
post Mar 2, 2003 - 7:20 PM
Tony-94
Joined Dec 17, '02
From UK
Removing the trim panel and taking the old stereo out is easy. I think the hardest part will be fitting the new radio because the gen 6 radio doesn't conform exactly to the normal DIN fitting used by almost every car. It wont slot in as easy as the Toyoya unit did and might need to adapt the new stereo's cage or mounting brackets. It is possible though.
(BTW You don't need to unplug the hazard or clock from the panel but it gives you more space to work in.)
post Mar 2, 2003 - 7:53 PM
Guest_Matthew_*
ya and you can use the stock mounting bracket and screw your new stereo into that bracket.
that is hard but the hardest thing for me is to find an adapter. none that i tried worked so i had to hardwire everything. makes it sound better than stock to. the speaker wires that i used are a lot higher of quality than the stock wires. I would suggest doing that if you have extra time. but you don't have to.
post Mar 3, 2003 - 12:13 AM
FallenHero
Joined Dec 26, '02
From Alabama
True enough. Also, when you get the regular DIN unit in place, it fits beautifully.
post Mar 3, 2003 - 12:38 PM
ashleyzredcelica
Joined Dec 22, '02
From Missouri
This post has been edited by ashleyzredcelica: Mar 3, 2003 - 12:40 PM
post Mar 3, 2003 - 12:39 PM
ashleyzredcelica
Joined Dec 22, '02
From Missouri
Yeah after its all done its looks awesome! tongue.gif It was worth the work. check out my installing story...trust me you'll be laughing!
click me!
post Mar 3, 2003 - 9:09 PM
Guest_Matthew_*
good link
This post has been edited by igotta5S-FEturbo: Mar 3, 2003 - 9:12 PM
post Mar 3, 2003 - 9:10 PM
Guest_Matthew_*
anybody have a write up?
This post has been edited by igotta5S-FEturbo: Mar 3, 2003 - 9:13 PM
post Mar 4, 2003 - 2:33 PM
Tony-94
Joined Dec 17, '02
From UK
It's strange, because when I tried to fit a single din head unit the radio was too wide to fit through the center console panel. It wouldn't fit 'underneath' the console panel properly either and just looked really untidy confused.gif might depend on the design of the head unit?
post Mar 8, 2003 - 12:11 PM
Nickb20
Joined Mar 2, '03
From U.K
O.k just tried installing my h/u and it was too wide to fit into the dash, any ideas or examples of what to do now smile.gif
Lo-Fi Version Time is now: May 17th, 2026 - 12:17 PM
