> rebuilding the 7a fte, possibly
post Sep 10, 2004 - 10:57 AM
OrbitalGT95
Joined May 3, '04
From pittsburgh
if i rebuild the 7a..what type of products should i use..like i'd wanted new pushrods, pistons, connecting rods, lifters, values and springs...anything else i should add to the list??..please help me out everyone
This post has been edited by OrbitalGT95: Sep 10, 2004 - 11:02 AM
Now SR powered
Replies (1 - 11)
post Sep 10, 2004 - 1:02 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (OrbitalGT95 @ Sep 10, 2004 - 7:57 AM)
7afe doesnt have pushrods, lol
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Sep 10, 2004 - 1:44 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
if ur gonna turbo it in the futur you might wanna go with a 4age head and intake manifold.
post Sep 10, 2004 - 1:48 PM
QUOTE (trdevelopment @ Sep 10, 2004 - 11:44 AM)
That involves a whole lot of work though, like re-wiring the harness, using a custom timing belt setup, etc. If you were going to do that, you might as well just swap in a 4A-GE or 4A-GZE and then turbo that. A 7A-GTE would be a lot of work...just ask frotou. wink.gif
post Sep 10, 2004 - 2:26 PM
OrbitalGT95
Joined May 3, '04
From pittsburgh
i wasn't planing on turboing it..i just wanted a good strong n.a engine..then maybe load some spray.....ya..my bad bout the push rods....anything else i should know
Now SR powered
post Sep 10, 2004 - 3:30 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
Well, if you don't want to turbo, next time write 7A-FE and not 7A-FTE. wink.gif
post Sep 10, 2004 - 4:40 PM
MK153
Joined Apr 13, '04
From St. Louis (Webster Groves)
I got this from the SVX owners group that im in.
From Danish_SVX of Subaru-SVX.net
"I have a Celica as well, including my SVX.
Make sure the engine you are getting hasn't been sitting outside in the rain, and make sure it hasn't been sitting with fluids indie of it. Make sure the fluids have been dumped out of it.
If you don't mind spending money, "Jasper Engines" sells remanufactured with 36,000 miles 3yr warranties on their engines and they have plenty of Toyota. Getting an engine from a scrap yard always has it chances of being bad and full of rust if they haven't been used. It's also a good idea when pulling an engine out of a scrap car that you change all the belts: timing and serpentine. And re seal the oil pan, valve cover, and head gasket.
From expierence I know it's quite invigerating to put Celica engines in. I've replaced two 5sfe in my Celica. Until I finally put a 3sgte (2.0L Turbo) in it which I feel is the best engine that yamaha ever made.
I would also suggest changing the whole engine and not just the short block if you are going to replace something.
In my opinion the best thing to do with your engine would be keep it. Bore it out and put some iron or steel cylinder sleeves in it, and replace the rod bearings to TOGA rod bearings which are alot stronger than the factory ones. Summitracing actually builds a rebuild kit for the 5sfe, 3sgte, 4afe, and the 7afe."
Thought that might have some usefull information.
post Sep 10, 2004 - 5:09 PM
OrbitalGT95
Joined May 3, '04
From pittsburgh
hey thanks mk for pointing me in the right direction
Now SR powered
post Sep 10, 2004 - 7:41 PM
MK153
Joined Apr 13, '04
Youre quite welcome...
post Sep 10, 2004 - 7:43 PM
OrbitalGT95
Joined May 3, '04
From pittsburgh
hey coomer..where and how much did u find you engine??
Now SR powered
post Sep 11, 2004 - 1:43 PM
blkGT
Joined Jun 10, '03
From FL
QUOTE (MK153 @ Sep 10, 2004 - 2:40 PM)
i disagree. my dads 250 v-max hpdi is a bad ass
jj buddy, my dads sponsored by yamaha, so we have lotsa boats with yamahas.
post Sep 13, 2004 - 2:43 PM
FallenHero
Joined Dec 26, '02
From Alabama
He Got it from Venus auto, and he will probably send you to Jarco inc.
Lo-Fi Version Time is now: September 2nd, 2026 - 4:01 AM
