Sep 12, 2004 - 8:55 PM
![]() Enthusiast ![]() ![]() Joined Oct 16, '02 From Hohenwald, Tennessee Currently Offline Reputation: 1 (100%) |
For the past couple of months, I've noticed a squeaking noise whenever I engage and disengage the clutch. I've only been able to notice it while idling. It doesn't always happen, but more often than not. Whether or not it does it while driving is a different story, I can't hear it over the sound of my engine.
Sep 12, 2004 - 10:15 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
I have the same problem. It can get pretty annoying
Sep 12, 2004 - 10:54 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
Wow, I thought I was the only one....lol
Sometimes its real loud, and other times I cant even hear it, but everything still works perfectly fine for me anyway. I'm guessing its just an old bushing or something. -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Sep 13, 2004 - 7:09 AM
sounds like the throw-out bearing
Sep 13, 2004 - 10:16 AM
Enthusiast ![]() ![]() Joined Jan 16, '03 From Wichita KS Currently Offline Reputation: 0 (0%) |
i thought that could be it because i have the same problem and my clutch is pretty worn. when i replace it it will be replaced as well so i'm not sweatin it
Sep 13, 2004 - 3:26 PM
So is there anything we can do to fix this?
Sep 13, 2004 - 3:28 PM
Well, you have to pull off the tranny to replace the throw-out bearing, which is not a fun job. -------------------- New Toyota project coming soon...
Sep 13, 2004 - 3:37 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 13, '03 From California Currently Offline Reputation: 2 (100%) |
when i changed my clutch i couldnt find the right throw out bearing....anywhere....turns out i have a tranny from a camry and the bearing is slightly bigger than our celis
but yeah that noise should be the throw out bearing and its long and tedious to change This post has been edited by fastgt: Sep 13, 2004 - 3:43 PM -------------------- 2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3 gone but not forgotten 2008 Space Grey BMW Z4 ///M 2009 Black Honda Civic LX Coupe 2006 Magnetic Black Nissan 350Z 2007 Crimson Red BMW 335i Coupe |
Sep 13, 2004 - 3:49 PM
![]() Enthusiast ![]() ![]() Joined Oct 25, '02 From London- England Currently Offline Reputation: 0 (0%) |
I had this problem on two occasions, first was sourced to the pedal lever
mechanism (usually a common feature on imported vehicles which are exposed to the sea air on the boat). A good can of WD40 and lots of elbow grease eventually will get rid of the noise. The other cause where the noise comes from the engine bay will usually be due to the clutch slave cylinder. Follow the clutch fluid resevoir to the first cylinder (master) then follow the fluid line to the slave cylinder near the front of the engine, need a good torchlight to see this. You may have to take any relay boxes etc to get your arms down into that area. Get someone to pump the clutch pedal and at the output end of the slave cylinder there is a rubber boot (the cylinder has a rod which moves an arm).Get your WD40 again and spray generously at the point the rod moves in and out of the slave cylinder.When the noise subsides just replace the boot and thats it. Hope this helps, Jon |
Sep 13, 2004 - 4:18 PM
I don't think it's from any of my parts being worn. I just had the clutch, throwout bearing, and pressure plate replaced about a year ago. Maybe when I'm not so lazy I'll dig a hole, fill it with WD40, and drive my car into it.
Sep 13, 2004 - 10:37 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
i have the same problem once in awhile also it comes and it goes.
Sep 14, 2004 - 9:06 AM
Enthusiast ![]() Joined Jul 30, '04 From colorado Currently Offline Reputation: 1 (100%) |
before u pull the transmission try replacing all the bushings on the pedal, iv'e replaced hundreds of bushings because of a squeaky clutch.
Sep 14, 2004 - 10:18 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
ya i have the same problem, but it sounds like its coming from down at the pedals, not in the back of my car, i can also feel some resistance... mine is definatly the bushings
-------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
| Lo-Fi Version | Time is now: August 26th, 2026 - 1:23 PM |
