Sep 27, 2004 - 3:36 PM
![]() Enthusiast Joined Dec 12, '02 Currently Offline Reputation: 0 (0%) |
I decided to paint my own spoiler, I bought the same color of my car in a spray can at an automotive store.
I sanded then wet sanded the spoiler, and I finished applying a few layers of primer. my question is, would it be better if I wet sanded the primer before I apply my paint? should I wet sand my last layer of paint before the clear coat? what's the best way for me to prevent chipping and what not thanks everyone |
Sep 27, 2004 - 3:44 PM
Enthusiast ![]() ![]() Joined Nov 29, '03 From Hampton, VA Currently Offline Reputation: 0 (0%) |
Yes you should wet sand the primer and the last layer of paint before the clear coat. You should also use a cleaner to keep oils from getting in the paint job.
Sep 27, 2004 - 3:46 PM
would varsol work as a cleaner? or would that strip away at the paint/primer
This post has been edited by dexterity: Sep 27, 2004 - 3:46 PM |
I didnt think you needed to wet sand the primer, as far as i know you just wet sand for final clear coat..
Sep 27, 2004 - 3:54 PM
You should definetly wetsand the primer. Any paint that fully dries should be sanded before more paint is applied. Sanding reopens the paints ability to bond with other paint. So because primer has to dry before color is put on it needs to be wet sanded. You might have to worry about chipping and cracking otherwise. -------------------- ![]() |
Sep 30, 2004 - 10:33 PM
Enthusiast ![]() ![]() ![]() Joined Apr 4, '04 From New York Currently Offline Reputation: 0 (0%) |
600grit wet sand primer
2200 grit wet sand color |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 4:20 AM |
