Oct 15, 2004 - 3:13 AM
Enthusiast ![]() Joined Aug 14, '04 Currently Offline Reputation: 0 (0%) |
I had to change the downpipe or header pipe, whatever its called(the pipe that connects to the exhaust manifold and ends before the catalytic converter), because of a huge dent. I got another pipe from TAP and also got new gaskets from the dealership. After I installed these items, there was sort of a putting sound(sorta like a quiet machine gun) that came from around the recently installed pipe. I can't tell whether the sound is from vibration or exhaust/air leakage. I thightened the bolts as much as I could, is there torque specifications for the bolts that connect to the exhaust manifold or something? 6g celicas are sexy cars, but if they sound funky, they lose their sex appeal. Sorta like a hot chick who farts and has bad breath... get what i'm saying? haha! Well please forgive my unknowingness, and any help would be appreciated
Oct 15, 2004 - 8:35 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
Sounds like a leak to me.
-------------------- Member of Team 5sfTe
Oct 15, 2004 - 11:36 AM
Enthusiast ![]() Joined Oct 15, '04 From Muskegon Currently Offline Reputation: 0 (0%) |
It could be vibrating on your “A” frame
Oct 15, 2004 - 12:19 PM
Enthusiast ![]() ![]() ![]() Joined Jul 7, '04 From charlotte N.C. Currently Offline Reputation: 0 (0%) |
is it a puttering sound, and do the sounds pace gets faster as you rev you engine?
like do the putters get closer together as your engine revs? -------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph. Next: maybe an elise |
Oct 16, 2004 - 10:15 PM
Yes thats exactly what it does. The puttering gets faster as the engine revs. Any ideas? |
Oct 16, 2004 - 10:35 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
Theres a leak somewhere, maybe use a breaker bar to tighten the bolts down more or try new gaskets.
Oct 17, 2004 - 1:30 AM
Oct 17, 2004 - 5:00 AM
start your car, pop the hood and carefully hold your hand over every place that was disconnected and new gaskets installed. You can and will feel the exhaust leaking from the said leak. If you do not feel anything then I'd take it to a exhaust shop.
Oct 17, 2004 - 11:29 AM
maybe you used some suck ass gaskets or something odd like that on accident. or maybe you over tightened them and cracked the gaskets.
just some thoughts. -------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
Oct 18, 2004 - 1:00 PM
This same thing happened to me when i was replacing my head gasket on my old car, the exhaust mani wouldnt seal, and it did the exact same thing. I used new gaskets, but after i torqued it down the first time, and it didnt seal, they were finished with. Make sure all of the old gasket material is off, as this will cause it to not seal. The second time around i used RTV grey gasket maker (supposedly for high temp and high torque gaskets, and used for imports... i dunno.) Try using that, and just make sure it has time to properly seal and harden up. That worked for me, hopefully that should work for you too.
Oct 19, 2004 - 12:47 AM
76 lbs, 80 lbs...etc? |
Oct 19, 2004 - 1:26 AM
Have you taken your car to a shop to look at it? High temp needs time to cure.
| Lo-Fi Version | Time is now: June 11th, 2026 - 11:32 AM |
