> clear side markers and signals for 97
post Nov 23, 2004 - 10:11 PM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
where can i get them the cheapest? also, are they just bolt on or do i need modifications? id rather just have them bolt on if possible.
Replies (1 - 8)
post Nov 23, 2004 - 11:05 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
www.procarparts.com carrys sets of both together.
http://www.procarparts.com/store-detail.as...e=onlinestoreDB
theres a direct link. its around 55$.
This post has been edited by BLINKYxMUNKEY: Nov 23, 2004 - 11:08 PM
FlickR
post Nov 25, 2004 - 11:35 AM
rocky2006
Joined Aug 18, '04
anyone have any install pics? they look like they would be kind of weird.
post Nov 25, 2004 - 11:53 AM
98celica3
Joined Aug 30, '02
From North Carolina
i had them on my celi. Here are some pics
adam
MISS THE CELI, BUT...
post Nov 25, 2004 - 4:56 PM
BenMMellor
Joined Dec 24, '02
From Wirral, UK
jesus .. don't spend $55.. just 1 min in a warm oven will make the front ones clear..
to make your facelift indicator lights clear.
get a small philips head screw driver - you'll need this later.
1. take the indicator lights out of the bumper.
2. heat the oven upto about 200 deg c. (gas mark 6)
3. put the light on a baking tray - put in the oven for about 30 seconds.
4. take the lights out of the oven. Prise of the clear front lense (the glue will be soft)
5. you will see an orange square lense. this is held in place by a small philips screw. remove it.
6. do the other light cluster.
7. put the parts back onto the tray and heat them again for aout 15 seconds.
8. remove them from the oven and push the clutser back to gether again so the glue seals them again.
9. Let them cool
10. Using a kebab stick or similar implement, use a pieve of absorbent paper to soak up any condensation or moisture in the lense.
11. you mith want to use soem clear sealant to just seal the edge.
12. using either orange bulbs, but preferably silver vision ones, replace the cluster.
all done - looks cool ! 30 mins tops !
for the side ones just get some avensis or corolla side repeaters from MrT. costs about £10 over here - so maybe $20 there. again get type 194 silvered bulbs that flash orange..
btw you do this at your own risk - if you neeed adult supervision ask for it !
don't try and sue me cos you damage yourself or something !!
post Nov 25, 2004 - 7:41 PM
rocky2006
Joined Aug 18, '04
if i do this: http://www.6gc.net/index.php?action=howto&itu=12
do i use the same bulbs or what?
post Nov 25, 2004 - 7:58 PM
Blakout16
Joined Jul 3, '04
From Yakima, WA
so those clear turn signals on procarparts fits on 94-95? i dont think it looks like it will.
post Nov 25, 2004 - 10:21 PM
rocky2006
Joined Aug 18, '04
it says 96-99 in the link
post Nov 25, 2004 - 10:43 PM
94-95 different than 96-99. There are no aftermarket turns for the 94-95. Just the side markers.
Lo-Fi Version Time is now: September 12th, 2026 - 7:00 AM
