Mar 19, 2003 - 8:19 AM
Enthusiast ![]() Joined Nov 20, '02 Currently Offline Reputation: 1 (100%) |
Does toyota have a special tool that fits in those small holes to remove the rear lights instead of taking the whole rear apart? I broke the small corner snap when I removed the rear plastic panel.
Mar 19, 2003 - 9:36 AM
i just used a deep socket to get the nuts off then i took off the middle rear panel to get to the wireharness..the panelholers are just these plastic screw style thingys...it shouldnt be hard at all...
Mar 20, 2003 - 3:43 AM
you could do what i did for a while i just took the lining out of my trunk but i had to put it back in.
Mar 20, 2003 - 12:46 PM
![]() Enthusiast ![]() Joined Dec 22, '02 From Missouri Currently Offline Reputation: 0 (0%) |
you should be able to buy them...if not then you should be able to order em. I bought mine from meeks or somewhere like that.
Mar 20, 2003 - 4:01 PM
![]() Enthusiast ![]() ![]() Joined Oct 25, '02 From London- England Currently Offline Reputation: 0 (0%) |
You should't have to remove the rear plastic panel. The corners at the back have off memory 3 or 4 large round
plastic covers with bulb symbols on them. Its just a matter of twisting them off, this will reveal a hole where you can push a deep socket head( as pressure 2 says) inside to loosen the nuts which hold the rear light assemblies. By the way if you try to take the plastic clips off in the future (the one you broke) remember you have to press the center part of the clip in with a screwdriver and then pull out the outer part of the clip. |
Mar 20, 2003 - 8:58 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
I didnt know that all you had to do was push in the ones on the doors and they popped out, my friend broke em all when trying to install my speakers.
| Lo-Fi Version | Time is now: September 21st, 2026 - 8:13 AM |
