Dec 18, 2004 - 2:31 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Well day one is starting today I hope to be done by monday. Can't wait I hate auto's!
Dec 18, 2004 - 3:21 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 22, '03 Currently Offline Reputation: 0 (0%) |
Pics?
Dec 18, 2004 - 3:28 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) |
Was really hoping someone would do it for a GT.
Dec 19, 2004 - 4:49 AM
Sorry not pics no digital camera, in 4 hours we got the tranny out, and flywheel and stuff out and most of the interior apart. I found out that my rear main seal is leaking so I had to stop till we get a new seal, hopefully autozone or pepboys has one and I can pick it up tommorow.
Akimbo, the gt is gonna be the exact same thing. I don't see what would be different about it. |
Dec 19, 2004 - 2:34 PM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 4, '03 Currently Offline Reputation: 0 (0%) |
QUOTE(Rjb23 @ Dec 18, 2004 - 2:31 PM) Well day one is starting today I hope to be done by monday. Can't wait I hate auto's! [right][snapback]223320[/snapback][/right] good luck dude and its well worth it. btw the wire to hook up to the clutch pedal is taped up into the bottom of the dash. you dont even need to plug it in unless you plan to buy the clutch pedal relay. I still havent and i love the fact that i dont need to push down the clutch to start it. QUOTE(Akimbo @ Dec 18, 2004 - 3:28 PM) Was really hoping someone would do it for a GT. [right][snapback]223345[/snapback][/right] akimbo nothing is different, your wiring harness maybe a bit different looking but im sure they wire colors are the exact same. -------------------- hows it taste motha f*cka |
Dec 19, 2004 - 10:11 PM
Hey sev, did all the plugs just match up to the manual tranny?
Dec 20, 2004 - 3:06 AM
ummm yes and no
obviously the main harness plug has to be cut up and i showed how in my How-To. also your reverse light plug needs to be changed. On the auto its a 3 prong if i remember correctly and on the manual its a 2 prong. You can either find the 2 prong from a junkyard or i just took this non conductive puddy that my dad had and i filled in the plug after i attached the wires. It holds very well and keeps water out and wont short out the wires. -------------------- hows it taste motha f*cka |
Dec 21, 2004 - 5:51 AM
Ok, today I found the replacment main seal and everything is almost back together, should finish it up tommorow. It would have been done today but the toyota dealer ordered the wrong bolts so, tommorow I need to find the 2 tranny bolts that are different. Everything is in except those 2 tranny bolts, the motor mounts, wiring and the axles.
Dec 22, 2004 - 6:36 AM
Well finished up today and so far so good. It is very much worth it to do this. My car drives so much better now. Only thing is I now have a flashing o/d off light, and a check engine light on because I havn't switched ECU's yet.
Dec 22, 2004 - 12:07 PM
Enthusiast ![]() Joined Nov 6, '04 Currently Offline Reputation: 0 (0%) |
so how much the total run you?
Dec 22, 2004 - 12:19 PM
Enthusiast ![]() Joined Mar 1, '04 From Louisville, KY Currently Offline Reputation: 0 (0%) |
hey, where in KY are you? I'm in Crestwood right outside of Louisville. I go to UofL for school
Dec 22, 2004 - 6:19 PM
Total it cost about $650 for all the parts.
I'm in louisville, I also go to U of L. |
Dec 22, 2004 - 7:03 PM
![]() Enthusiast ![]() ![]() Joined Dec 3, '04 From torrance, ca Currently Offline Reputation: 0 (0%) |
are you going to do a write up or is it basically the same thing as sev's auto-manual st guide?
Dec 22, 2004 - 8:28 PM
Na no write up, his was pretty much spot on, the only thing different I did had to do with the wiring, instead of cutting the wires out of the plug to bypass the neutral safety switch(the big grey plug in his write up) I just jumped the wires by putting a pin connecting the 2 pins in the plug and taped it up with electrical tape. Also the top tranny mount the 12 x1.25 65 mm bolt I don't think was 65 mm, it looked like 55 mm and the toyota dealer said it was 55 too. They gave me 2 70mm bolts and I had to cut one down. I had to cut off more then 5 mm. Also more trouble I ran into was I bought a manual ECU and the last plug did not work with my wiring harness, my plugs were 26 16 22 the manual ecu is 26 16 12 still working on figuring this one out. You can use your auto ecu you just get a flashing o/d off light and a check engine light all the time.
Dec 23, 2004 - 3:22 AM
Enthusiast ![]() ![]() ![]() Joined Aug 20, '03 From Seattle, Washington Currently Offline Reputation: 0 (0%) |
it only cost 650 for the tranny and everything wow!
Dec 23, 2004 - 6:23 AM
Enthusiast ![]() ![]() ![]() Joined Nov 6, '03 From Campbellsville, Ky. Currently Offline Reputation: 0 (0%) |
Now that your done, drive down and do mine for me.
Dec 23, 2004 - 6:49 AM
Yeah I got the tranny for $200, the clutch kit was $150 and most of the shifter parts, pedals and such were $100 and the flywheel was $30, the ECu was $75(which I haven't used yet), and misc stuff was $80(like shifht nob, bolts, oil, getting the flywheel turned).
Gas, you should have no problem doing it, its basically just like taking out a transmission and putting a new one in, the inside stuff is the only thing that you have to do different. That took a few hours putting in the pedals is the hardest part because of the angle, its kinda hard to get to. |
| Lo-Fi Version | Time is now: September 4th, 2026 - 12:37 PM |
