Jan 5, 2005 - 2:21 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
I made this thread basically for archival purposes. I have a 95 Celica ST and installed 92 GTS rear disk brakes on it. They work fine... just be sure to adjust the E-brake before you install the rotors.
Jan 5, 2005 - 3:58 PM
QUOTE(FallenHero @ Jan 5, 2005 - 12:21 PM) I made this thread basically for archival purposes. I have a 95 Celica ST and installed 92 GTS rear disk brakes on it. They work fine... just be sure to adjust the E-brake before you install the rotors. [right][snapback]230313[/snapback][/right] have any pics??? -------------------- yea your 3sgte is cool but ill stick to my 7agte
Jan 5, 2005 - 4:18 PM
Did the e-brake cables from the fifth gen. GT-S work?
Jan 5, 2005 - 8:32 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 27, '03 From Nor Cal Currently Offline Reputation: 0 (0%) |
QUOTE(Coomer @ Jan 5, 2005 - 9:18 PM) Did the e-brake cables from the fifth gen. GT-S work? [right][snapback]230365[/snapback][/right] I'm curious about the same thing... -------------------- "It's ok to be naked girl... I'm an artist!"
Jan 5, 2005 - 8:42 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
I had the e brake cables from the 5th gen. I Didn't use them, though they looked liked they would fit. I just cut my ebrake cable from my ST to match the length that was on the 5th gen. Works like a charm.
Jan 7, 2005 - 3:37 AM
yes, the 5th gen e-brake cables worked, as did Jeremys brake lines.
to fit the cables though, the exhaust has to be removed. |
Jan 7, 2005 - 4:37 PM
interesting
i will have to look into this more.. how long did your installation take? |
Jan 7, 2005 - 5:22 PM
if you didn't do rotor and pad swaps like me, all you have to do is unbolt one housing and bolt in the other. I don't do brake work, so I had them installed locally.
Jan 8, 2005 - 2:18 AM
thw swap took me like 5 hours. It was the first major project I had to deal with on my car so I took my time. If you know what you are doing, then it shouldn't take too long at all. I could prolly do it in like 2 hours now. I also had a caliper freeze, didn't have right brake lines so that delayed me even further. But it really isn't that hard at all. Just time consuming
Jan 8, 2005 - 6:01 AM
how did you guys go about on tuning these breaks.
isn;t it dangerious to have more stoping power on the rear then the front? |
Jan 10, 2005 - 2:31 AM
The disks are similar size, but the system proportions more pressure to the fronts. It's no problem.
Jan 10, 2005 - 2:59 AM
QUOTE(Hanyo @ Jan 8, 2005 - 11:01 AM) how did you guys go about on tuning these breaks. isn;t it dangerious to have more stoping power on the rear then the front? [right][snapback]231339[/snapback][/right] There isn't much "tuning" needed. The rear discs should stop as normally as did the rear drums. The proportioning valves seems to be the same between the ST drums and GT discs. The differences in pressure may be related to the brake lines, which the ST drums use small metal lines and the GT calipers use typical rubber lines. Also, the rear never brakes more than the front in normal situations. -------------------- "It's ok to be naked girl... I'm an artist!"
| Lo-Fi Version | Time is now: September 18th, 2026 - 6:50 AM |
