> My Car Shakes, Whats Wrong?
post Jan 9, 2005 - 10:52 PM
jojobombiest
Joined Sep 10, '03
From Santa Barbara, CA
Just over a week ago I noticed that the celica starts to shake alot when im going fast and i push on the gas pedal... the whole car just shakes violently... It's fine when im just coasting but when i push down the gas it starts to shake really bad. It started out doing it when i was going about 60mph, but today it started doing it at like 40... whats wrong? confused.gif
Replies (1 - 16)
post Jan 9, 2005 - 10:58 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
uhmmm i know in a rear wheel drive vehicle that that problem would be the u joints but in the celi i'm not sure on that one. it's not the tires off balance cuz it would shake when you take the foor off the pedal.... does it do it in any other gear at high rpm?
This post has been edited by rjbibeau: Jan 9, 2005 - 10:58 PM
post Jan 9, 2005 - 11:01 PM
jojobombiest
Joined Sep 10, '03
QUOTE(rjbibeau @ Jan 9, 2005 - 7:58 PM)
[right][snapback]231817[/snapback][/right]
it does it starting at about 40mph so i guess that would be 3rd gear and 4th gear.. its an automatic
its always shaken a little bit but just recently its gotten really bad frown.gif
This post has been edited by jojobombiest: Jan 9, 2005 - 11:02 PM
post Jan 9, 2005 - 11:03 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
does it throw a check engine light at all??? it's prob the torque converter. do you have enough atf fluid in there?
post Jan 9, 2005 - 11:13 PM
jojobombiest
Joined Sep 10, '03
QUOTE(rjbibeau @ Jan 9, 2005 - 8:03 PM)
[right][snapback]231823[/snapback][/right]
The light doesn't come on at all...
post Jan 9, 2005 - 11:16 PM
spunky393
Joined Apr 22, '04
From illinois
check your engine mounts
The most important lesson I learned from Karate-Dō Kyōshan“You can not be what you do not believe you are”
post Jan 9, 2005 - 11:24 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
ya engine mounts could be it too... good one
post Jan 9, 2005 - 11:54 PM
yeah i agree...most of the time if the engine runs good but the car shakes, then its the motor mounts.
post Jan 10, 2005 - 12:19 AM
jojobombiest
Joined Sep 10, '03
post Jan 10, 2005 - 12:26 AM
Anub1s
Joined Nov 27, '03
If the engine shakes violently under load its most likely the Engine mounts. Tranny could have something to do with it but very unlikely.
post Jan 10, 2005 - 2:47 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
Get your wheels aligned?
This post has been edited by CheesyLobster: Jan 10, 2005 - 2:47 AM
post Jan 10, 2005 - 3:41 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(CheesyLobster @ Jan 9, 2005 - 11:47 PM)
[right][snapback]231894[/snapback][/right]
and balanced
vibration at speed is almost always due to the tires being out of balance
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Jan 10, 2005 - 12:25 PM
klr_toy
Joined Feb 18, '03
From Hermiston, OR
might check your axles. When mine went out they were fine coasting but under load you could really feel it. Wasn't bad at first but after awhile they got a lot worse and it was definetly time to change them. just a thought
post Jan 10, 2005 - 12:39 PM
BlackCelicaGT94
Joined Mar 4, '03
From Kirkland, Washington
wheels might be bent. i bent mine and havent fixed them and my car shakes. Sucks in the rain cuz im all over the place like a drunk
post Jan 10, 2005 - 3:04 PM
95gtschick
Joined Sep 18, '04
From Manitoba, Canada
happens out here if you get assloads of snow by your brakes/wheels, but i'm assuming you don't have that problem...
post Jan 10, 2005 - 3:15 PM
eclipse_04a
Joined Aug 22, '04
From Menomonie, WI
its either the mounts for axles...if the tire is out of balance, it would still shake when its coasting. my bet is the axles personally....just replaced mine a month ago.
post Jan 10, 2005 - 4:43 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
QUOTE(97sccelica @ Jan 10, 2005 - 3:41 AM)
and balanced
[right][snapback]231908[/snapback][/right]
Yup if your car steers in a given direction other than straight when u let go of the wheel then u need alignment. if it shakes than u need balance. If its not either check your mounts.
Team 6gc 2005
Lo-Fi Version Time is now: August 27th, 2026 - 11:06 AM
