Feb 3, 2005 - 11:57 PM
Enthusiast ![]() ![]() Joined Aug 26, '04 From St. Cloud, Minnesota Currently Offline Reputation: 0 (0%) |
I am planning on replacing my atenna with a S2000 atenna. The problem is my atenna does not go up anymore. I just installed my new CD deck about 1 week ago and thats when it doesn't work anymore. My atenna doesn't go completely down, it is down and is at the last section of the atenna at this moment.
So is it still ok to cut it off or do I have to completely raise the atenna? |
Feb 4, 2005 - 5:37 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Just disconnect the wires, and pull the atenna up by hand. Your going to have to disconnect the wires anyway to put the s2000 antenna on.
Feb 4, 2005 - 1:29 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
if you get a 7th gen mount you can switch them easily then screw the s2k antenna on
Feb 4, 2005 - 3:01 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) |
QUOTE(mikew04 @ Feb 4, 2005 - 1:29 PM) if you get a 7th gen mount you can switch them easily then screw the s2k antenna on [right][snapback]242062[/snapback][/right] ^ What I did. Really easy. -------------------- |
Feb 4, 2005 - 3:22 PM
cool thanks for the advice.
Feb 7, 2005 - 1:02 PM
I have a power antenna but I dont want to cut the mass, since i can resell it! whats the easiet way to disconnect the whole system..through the trim and unhook it?
Feb 7, 2005 - 2:52 PM
take the interior panels off, disconnect the wires, unscrew it, and disconnect the fm connector.
| Lo-Fi Version | Time is now: August 31st, 2026 - 6:32 AM |
