Feb 25, 2005 - 11:11 PM
Enthusiast ![]() ![]() ![]() Joined Mar 20, '04 Currently Offline Reputation: 3 (100%) |
Hey finally got some pics of my car since it got hit a month or two ago. Can I fix this by myself?
This post has been edited by celicaboston1983: Feb 25, 2005 - 11:12 PM |
Feb 25, 2005 - 11:26 PM
Enthusiast ![]() ![]() ![]() Joined Oct 12, '04 From Montgomery, AL Currently Offline Reputation: 1 (100%) |
i think you can it doesn't look like it's buckled anywhere. you can probabilily get that out.
Feb 25, 2005 - 11:29 PM
Enthusiast ![]() ![]() Joined Dec 28, '04 From New Jersey Currently Offline Reputation: 0 (0%) |
use metal working hammer and rubber mallet ...go buy it a automotive shop ...that all u need ....gl with it tho..
-------------------- ![]() As the time goes by My life change... I hope i wont change Nor my heart but it is broken..wat can i do.. IT life...I hate it...but i lov my creation |
Feb 26, 2005 - 12:07 AM
try pops-a-dent
![]() J/K just thought to lighten it up a bit -------------------- |
Feb 26, 2005 - 1:31 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) |
No, you can't fix that. You need to get ahold of a body man to look at that for you. I recomend Bigmeanbulldog55. You give him a few bucks and he'll take it out for you.
Seriously though, you can get them out a little. I'd have too see some better picks to tell you exactly what to do. But your best bet is going to be taking the panels out on the inside and pushing the dents out. This is going to be a little more time consuming, but you could end up just hurting the situation from going at it from the outside. You'll never be able to get that perfect without some puddy(or lead if you like), but you can get it close if you take your time. One more thing, try to use your hands as much as you can before you try using a hammer or any other tool. This will keep you from putting dents in that don't belong. Metal will try to go back the way it was if you use your hand. More pics could help, if you have anymore question you can pm me. There's a few more poeple on here who know a good bit about this stuff, you can try to find them and ask them too. EDIT: I was looking at the picks again and..... that really doesn't look to bad. You'll be able to get all that with your hand, don't use a hammer or mallet at all. This post has been edited by Bigmeanbulldog55: Feb 26, 2005 - 1:34 AM -------------------- Live Free, Be Happy
Feb 26, 2005 - 1:47 AM
Enthusiast ![]() ![]() Joined Feb 16, '05 From south carolina Currently Offline Reputation: 0 (0%) |
damn good luck with that
Feb 26, 2005 - 3:41 AM
![]() Enthusiast ![]() Joined Aug 13, '03 From Greencastle, PA Currently Offline Reputation: 0 (0%) |
thats almost the same as what happened to mine. Just take off the panel as if you were changing the rear speakers and take a block of wood and hammer that to keep from putting the hammer marks on the exterior. I had paint taken off also so I just hit the wrinkles with some bondo to smooth it out. You also might want to take and put a peice of v-bar or some kind of support in there if the peice seems to pop in and out too easily.
Feb 26, 2005 - 3:55 AM
![]() Enthusiast Joined Feb 4, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
ur so lucky the door is fine! (from what i can tell). otherwise you'd have two panels to patch and paint.
and that car is filthier than mine and atm, my car is freaking filthy - rally spec |
Feb 26, 2005 - 4:54 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
I think you can. It dont look that bad. Buy a stud welder/puller, there cheap these days and weld some studs so you can pull out most of the dent
Feb 26, 2005 - 12:08 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '04 From Rhode Island Currently Offline Reputation: 3 (100%) |
if thats rust on there make sure u take care of that
Feb 26, 2005 - 12:44 PM
Ill try to take better pics when the car is cleaner. I would try to attempt to fix it up a bit but its been cold out.
Feb 26, 2005 - 12:46 PM
Enthusiast ![]() Joined Feb 26, '05 From Venezuela Currently Offline Reputation: 0 (0%) |
good luck brother...
-------------------- TOYOTA PARKING ONLY all others will be crushed...
![]() P®¡n©iÞ€MB marvi75@hotmail.com SOPHIA & EZEQUIEL are my life!! I love them!! |
Feb 26, 2005 - 1:52 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
Hey, if it makes you feel better, i had a dent about 3 times as deep as that, but I got it fixed because of insurance money. I suggest taking it to a good shop though, because otherwise you'll be able to tell they fixed it.
-------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Feb 26, 2005 - 2:06 PM
QUOTE(madmods @ Feb 26, 2005 - 9:54 AM) I think you can. It dont look that bad. Buy a stud welder/puller, there cheap these days and weld some studs so you can pull out most of the dent [right][snapback]250362[/snapback][/right] Thats what i was gunna say.. Shouldnt be to hard, your going to need to use some puddy too.. gl |
Feb 26, 2005 - 2:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
that dent looks familiar, I have one same spot but its not that bad, and POP'S A DENT does not work for $%&# what a waste of 20 bucks. Mine was a garage incedent where the endge of the garage was not looking where it was going and ramed right into me.the little trickster. anyway i'm taking it to a body shop in a few weekss where there gana fix that, and paint my doors/hatch.
good luck, I would put a little extra in it and have a shop do it, rather then try it yourself, unless you know you can, its just not worth it to try alone I think. This post has been edited by creis: Feb 26, 2005 - 2:51 PM -------------------- ![]() |
| Lo-Fi Version | Time is now: September 20th, 2026 - 9:33 PM |
