> Power Antenna, Need Help Hooking it up with my Stereo
post Feb 26, 2005 - 12:16 PM
RbrtNdrws
Joined Jul 8, '04
From Durham, NC
Hi,
I recently put in a Pioneer HU in my car, and there was a wire coming out of the back that said "Power Antenna". Well, I thought that the wire coming from inside my dash that was for the antenna was some sort of plug shaped wire.. If you know what I mean.
Well, I tried touching that connector to the bare wire of the wire coming out from the stereo, and it did not work.
How can I get my antenna functioning??
Yes, I did try searching for it but I couldnt find anything. So please dont yell at me, just help me out.
Thanks,
Rob
Replies (1 - 3)
post Feb 26, 2005 - 1:00 PM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
there are 2 wires lableled "power antenna." i know because with my Pioneer HU, the antenna would go up when i listened to cd's so i installed a switch for my antenna. i put it on one of the wires and it didnt work. i then found another wire labeled the same and it worked. just try to find the other "power antenna" wire.
post Feb 26, 2005 - 11:58 PM
RbrtNdrws
Joined Jul 8, '04
From Durham, NC
i've checked all the wires, and mine only has one..
what should i do
post Feb 27, 2005 - 12:37 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
The big fat wire with the connector is your antenna. It get hooked into the back of your hu. There should be a place it fits into. In the stock wire harness look for 2 wires one is pink/blue and one is black/red. Connect the blue power antenna wire to both of the wires in the stock harness. They both need the 12vdc + from the radio to activate the stock antenna to got up.
Lo-Fi Version Time is now: August 31st, 2026 - 4:59 PM
