Mar 13, 2005 - 10:45 PM
Enthusiast ![]() ![]() Joined Aug 19, '04 From Maine Currently Offline Reputation: 0 (0%) |
OK since no one decided to answer my last question, I have another, I have a MAP issue going on with the sensor and its screwing my car up, NOW when i bought my turbo kit I recieved a black box thats supposed to be a MAP sensor of some sort, now im not sure if its to replace it or not....its got
Red : +5v Black: Ground Green: Not Used White: MAP pressure signal IN Blue: MAP pressure signral OUT NOW the instructions : "CUT MAP PRESSURE WIRE, CONNECT WHITE WIRE IN AND BLUE WIRE OUT" Does this completely replace the old unit or is it just a piggyback.............. anyone have pics of what exactly its replacing, or how its installed or where? |
Mar 14, 2005 - 5:44 PM
Enthusiast ![]() ![]() Joined Aug 27, '04 From Orange County, CA Currently Offline Reputation: 0 (0%) |
QUOTE(d3monc3lica @ Mar 13, 2005 - 8:45 PM) OK since no one decided to answer my last question, I have another, I have a MAP issue going on with the sensor and its screwing my car up, NOW when i bought my turbo kit I recieved a black box thats supposed to be a MAP sensor of some sort, now im not sure if its to replace it or not....its got Red : +5v Black: Ground Green: Not Used White: MAP pressure signal IN Blue: MAP pressure signral OUT NOW the instructions : "CUT MAP PRESSURE WIRE, CONNECT WHITE WIRE IN AND BLUE WIRE OUT" Does this completely replace the old unit or is it just a piggyback.............. anyone have pics of what exactly its replacing, or how its installed or where? [right][snapback]256894[/snapback][/right] I never cut or spliced any wires. Theres a connector on the part. Bottom end of the map sensor had an open port for the Vac line. Side end of sensor had the same connector as my 5SFE stock map. Basically just unplugged both, and plugged them into the new 2 bar sensor. Sounds like you have something different. Post some pics. -------------------- ![]() |
Mar 16, 2005 - 1:46 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
dude you have a supra one. wrong map. get a mr2 one or all trac one they'll both work. or if your goin piggy back just get a cheap 3 bar GM one.
Mar 17, 2005 - 1:58 AM
poopey.....
Mar 17, 2005 - 2:04 AM
Im a bit confused, can someone take a pic of the MAP for me on the stock ST, a frikin dealership couldnt describe it because the pic they had sucked, so if anyone could, please post a pic.
| Lo-Fi Version | Time is now: September 4th, 2026 - 5:02 PM |
