> How much oil pressure should my t3 see?
post Mar 22, 2005 - 3:42 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i think im running to much pressure causing the seals to leak oil and smoke. its nothing horible but just enough to get me mad. so right now it gets 25 psi at idle and is fine but at like 3k and up it gets 50psi. so any ideas?>
Replies (1 - 5)
post Mar 22, 2005 - 4:02 PM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
I talked to SFP about this on my t3/t4. I thought that 1/8" braided line will be too thin. They told me that with 1/4" line, it gets too much oil pressure, but 1/8" line is perfect. However they didn't give me a figure on what the oil pressures are with each. Could there be another reason you are seeing smoke from your exhaust. Brand new exhausts will smoke for a couple months. I see 70psi at the top of my head(at WOT), and from there the oil line is T'ed off to the turbo. At idle I only see about 15psi, which is fine, but sometimes drops when the motor is very hot. This worries me a bit b/c it's almost too low.
post Mar 22, 2005 - 6:15 PM
post Mar 23, 2005 - 12:21 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
yep -3an for feed and -12an for return
post Mar 23, 2005 - 2:20 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(x_itchy_b_x @ Mar 22, 2005 - 12:42 PM)
[right][snapback]260773[/snapback][/right]
i think they normally start to leak around 75psi
get a couple different size restrictors and try them out until you find one that stops the leaking.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Mar 23, 2005 - 4:58 PM
erics1one
Joined Aug 27, '04
From Orange County, CA
Also...
If you have excessive crankcase pressure, more oil will push into your turbo, which will slowly coke the seals, and eventually the oil seals deteriorate.
To test this, 'Bryon' on mr2oc forums slipped a hose onto his dipstick opening and monitored the pressure with a gauge. Your engine and turbo will operate best with a slight vacuum on the crankcase, therefore if you have a +psi readings off your oil pan gauge, you have excessive blow by.
This is my understanding after extensive talks with Byron and Presure2.
Lo-Fi Version Time is now: May 30th, 2026 - 11:50 AM
