> do i need to change my plugs/wires?
post Apr 4, 2005 - 1:52 AM
Yota
Joined Feb 27, '04
From Illinois
Today, while accelerating, my car started to 'stutter' a little bit. It was kind of odd. Then it started to do it repeatedly everytime I'd accelerate moderately hard. Would this be a fouled out plug? Is this a normal symptom of having to change plugs? The car has 89k miles on it and I dont know if the previous owner ever got them changed.. Should I replace the wires as well? How much am I looking at spending? I really hate to do this since I'm swapping in the 3S, but it is my only car and I need it running until the day of the swap!
Thanks,
Yota
Replies (1 - 9)
post Apr 4, 2005 - 2:15 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(Yota @ Apr 4, 2005 - 1:52 AM)
Thanks,
Yota
[right][snapback]266194[/snapback][/right]
Sounds like some bad gas to me. I'd replace everything anyway though. But that's just the way I do things. Better to fix it before it breaks than to get stranded somewere, or have your car all screwed up.
Live Free, Be Happy
post Apr 4, 2005 - 11:29 AM
change the spark plugs, dist cap and rotor. all those are cheap . if the problem continues, then do the wires.
post Apr 4, 2005 - 11:35 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
could be a O2 sensor too, bad air to fuel mix.
post Apr 4, 2005 - 11:37 AM
LewFX, if it was the o2 sensor,then it would throw a check engine light.
post Apr 4, 2005 - 11:50 AM
LewFX
Joined Jan 28, '05
mine never did, and that was replaced at my local toyota dealership
post Apr 4, 2005 - 1:58 PM
Yota
Joined Feb 27, '04
From Illinois
How much am I looking to spend on plugs, cap and a rotor?
I doubt it'd be bad gas...I filled up today and the problem continued... I also have no check engine light on..
post Apr 4, 2005 - 2:01 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Mine did that to when i first got it, but it as an extemely dirty air filter
post Apr 4, 2005 - 10:50 PM
exxtractor
Joined Mar 31, '03
From BC
lagos I had an O2 sensor that wasnt' connected, it does not turn on the check engine light. Turst me on that.
This post has been edited by exxtractor: Apr 4, 2005 - 10:50 PM
post Apr 5, 2005 - 12:32 AM
97GTinKC
From KC
cheap - easy way to check the wires is to find a really dark spot at night and check for arcing along the wires, mist a little water over them from a spray bottle, if they are leaking voltage, you'll see it. another symptom of bad wires is hard starting when damp out. you can sometimes make them last a little longer by cleaning the wires off.
Lo-Fi Version Time is now: May 18th, 2026 - 4:23 PM
