> Rear disk brake swap info, e-brake cable
post Apr 17, 2005 - 1:39 AM
how do i modify the e-brake cable so that it can fit on the st?
cause right now i have a ton of slack and its not pulling at all
and i'm using the GT cable right now
Replies (1 - 24)
post Apr 17, 2005 - 3:00 AM
AndyST4
Joined Feb 3, '05
From Portland, OR
I used the st upper part of the cable and the gt sable and it worked perfect for me
post Apr 17, 2005 - 5:24 PM
sable?
can you define for me please?
by sable are you refering to the part after it splits into two pieces
post Apr 17, 2005 - 8:22 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
i took a bolt cutter and just chopped off an inch or so. Then I had to by a metal stop thingy at ACE that went on garage doors so that it would hook on the brake. Works like a charm
post Apr 18, 2005 - 10:15 AM
ok so i can just cut it
and then use a clamp to hold it together
sounds good thanks
post Apr 18, 2005 - 1:41 PM
AndyST4
Joined Feb 3, '05
From Portland, OR
QUOTE(playr158 @ Apr 17, 2005 - 5:24 PM)
sable?
[right][snapback]272753[/snapback][/right]
definition of sable; me being stupid and hitting the "s" instead of the "c" key and not noticing it until now
post Apr 18, 2005 - 1:52 PM
AndyST4
Joined Feb 3, '05
From Portland, OR
I don't understand why some people get slack when they do this conversion and some people don't?
post Apr 18, 2005 - 5:30 PM
yea i have the upper st and lower gt
its weird i tell you
post Apr 18, 2005 - 6:44 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
From Spring Valley, NY
can i use the stainless steel brake line kit from NOPI to convert my rear drums to GT discs??
thanx
alex
post Apr 18, 2005 - 6:46 PM
Isn't there a but that adjusts cable tension up near the e-brake if you pull off the center console cover? I was thinking that there was.
And also, does anyone have pictures of modified ST cables? I have the cables from a fifth gen. GT-S, but they're torn in a couple parts and the metal cable is exposed, so I may use the ST cables.
post Apr 18, 2005 - 7:12 PM
yea you can adjust it there i have like 6-10 bolts to hold it tight on the car now and it does nothing
you have to go in a cut if its too long
post Apr 18, 2005 - 7:47 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
i dont haqve slack i just cut the black plastic circle thing and put it back on...
post Apr 19, 2005 - 6:36 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Sorry for being such a n00b.
What do I need for the rear swap ?
Calipers, pads, rotors, hubs Am I missing anything ?
Edit BTW I love you guys
DEF
This post has been edited by defgeph: Apr 19, 2005 - 6:37 PM
I will return one day.
post Apr 19, 2005 - 6:45 PM
hahahaha def you lmao
yea you need a gt e-brake cable, calipers, rotors, pads, the backingplate with the e-brake assembly stuff.....
basically
the cable and everything attached to the rear hub incl. the hub
if you can then MY advice is go to a junk yards
find a GT
and unbolt the WHOLE hub in 1 piece with rotor and caliper attached ...
then pull the cable
the just bolt the new full hub assembly back on and reattach the cable and a lil bit of brake line and your good to go...
post Apr 19, 2005 - 8:48 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
how bout converting my ST front to GT...snivesatgt looked up the backing plate for me and said that the parts number for GT and ST are different. i bought the spindles w/ hub and backing plate from a junk yard. i already have the crossdrilled and slotted rotors and calipers for a GT and still need to order stainless steel brake line
now installing it is another story. anyone with an ST ever done this?
how hard would it be? would i have to take out the axle to remove the backing plate??
i have no clue how to install this
PLEASE HELP
THANX
ALEX
This post has been edited by Ve1Ls1dEvolutioN: Apr 19, 2005 - 8:49 PM
post Apr 19, 2005 - 8:54 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Dan,
Driving the honda has gone to my head. lol
I've read that you guys just modified the cable you already have ?
Whats the story with that ?
Defster
post Apr 19, 2005 - 9:25 PM
oh god the civic
post Apr 20, 2005 - 10:20 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
ok two questions
Will the 5th gen celica rears work ?
Also is the brake booster form the st enough to handle rear disc?
post Apr 20, 2005 - 10:23 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
yes on both.
Team 6gc 2005
post Apr 20, 2005 - 10:27 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE(Drocay @ Apr 20, 2005 - 10:23 AM)
yes on both.
[right][snapback]274649[/snapback][/right]
Sweet i think i just found my next project.. cause the junkyard is full of rear deisc set ups. I thought the 5th gen were 4 bolt though..
Also has any one had problems with using calipers from junkyards?
post Apr 20, 2005 - 12:04 PM
Jeremy1210
Joined Dec 16, '02
1 of mine were frozen, no bigge just got a new one
post Apr 20, 2005 - 12:53 PM
personally
just get ones from the junkyard
and then go to advanced and trade them in as a core
and get remanufactured calipers
along with new rotors and pads
post Apr 20, 2005 - 2:54 PM
Doug,
Some STs(and maybe GTs/GT-Ss) are four-lug. I do know for sure that a lot are five-lug though. I got my rear disc stuff off of a fifth gen. GT-S and it was five-lug.
Daniel, how much do new calipers cost if you've got cores(for regular people?)
post Apr 20, 2005 - 5:19 PM
guessing probably like 70$ or so a piece not really sure i'll have to check tonight
post Apr 20, 2005 - 10:44 PM
MonsterBOX
Joined Jan 8, '05
From Alabama
how big of a diff do you all notice over st front brakes by having all 4 discs from gt
Lo-Fi Version Time is now: August 11th, 2026 - 11:40 PM
