Apr 22, 2005 - 12:21 AM
Enthusiast ![]() ![]() ![]() Joined Apr 4, '05 From ST PAUL, MN Currently Offline Reputation: 3 (100%) |
ok i have 1300 bucks to spend im thining about doing the 3s swap but also looking toward to do the 2.2block with the 3s head..so hwo much does the 3s cost total.
Apr 22, 2005 - 1:46 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 3, '04 From Yakima, WA Currently Offline Reputation: 1 (100%) |
mmm use search button it wassss just covered alittle bit ago i think and they averaged around 3000 dollars
-------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Apr 27, 2005 - 10:11 AM
Enthusiast ![]() Joined Feb 23, '05 From Bozeman Montana Currently Offline Reputation: 0 (0%) |
yea man try searching before you ask this has been covered at least twice by me alone so i know its got around7-8 posts -but ive seen averages from 3k to 9k and those who had 3k did all of their own work and had almost all of the parts...
Apr 27, 2005 - 10:18 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Yeah I'm doing a 3SGTE swap for someone in a month and it's costing him around 5 Gs... and I hardly charge anything.
-------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Apr 27, 2005 - 11:05 AM
Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
budget 5 g's for the 3s swap and don't think about the 2.2 block with the 3s head. As far as I know it still hasn't been done with full success and anyways, you can just bore and stroke a 3s motor to give you the same displacement.
Apr 27, 2005 - 12:19 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
clip would run around anywhere from 2000 to 2500 without shipping. shipping for a clip is expensive. anywhere from 300-500 or may even run as high as 800 depending on ur location and location of where u getting it at. engine can run anywhere from 1200-1800 and shipping for these should fall around 250-500 again depending on ur location. oh btw this is refering to a st185 clip/engine since theyre the most commonly used. st205 is more expensive. then theres all the other costs... labor and xta parts
bboy This post has been edited by BBoYRuGGeD: Apr 27, 2005 - 12:20 PM -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
Apr 27, 2005 - 1:45 PM
yeah im try to talk to this guy who could hook me up with another clip a st205 clip for about 17hundred..its in texas somewhere..im thinking buy it and then just go and pick it up..
Apr 27, 2005 - 3:19 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Charlotte Currently Offline Reputation: 0 (0%) |
Yeah, you might as well go for the full swap, it's hard to find a head and even if you did it's made for a low compression engine. Seeing that you want to use the 5S block you'll be running a really low compression and you'll actually lose power. You could use it but you'll also need high compression pistons and those alone would run most of your $1,300.
Apr 27, 2005 - 3:22 PM
Enthusiast ![]() ![]() ![]() Joined Oct 10, '04 From New Jersey Currently Offline Reputation: 0 (0%) |
3sgte engine the engine is 1300 here. plus shipping, so keep saving
Apr 27, 2005 - 8:56 PM
ooh man thanks ill take a look at it..and yeah im saving but i do have enough
| Lo-Fi Version | Time is now: May 16th, 2026 - 1:48 AM |
