> Engine lunging at low RPM
post Apr 23, 2005 - 5:46 PM
king_wsk
Joined Mar 17, '05
From Northridge, CA
I notice when i'm in 1st and 2nd gear, while in stop and go traffic, my GT jumps a bit every 10 or so seconds just a bit, enough to make me loose good throtle control. It only does it when the engine is barely above idle, around 1000-1700rpm.
I've also noticed that if I leave the car on for 5-10 minutes just idling, the rpm will occationally drop from a healthy 1000rpm to 700rpm for a second once every 20-30 seconds.
Any ideas on whats going on here? I think it has something to do with my sparkplug wires as when I got the car, one of the plug wires wasn't all the way connected and occationally comes slightly out of the socket, but not enough to not fire. Even after I make sure the plug is on fully, it still does the same things.
Replies (1 - 16)
post Apr 23, 2005 - 6:41 PM
wow you got sum motor issues
check (or get new)
cap, rotor, wires, plugs,
clutch (and assembly)
there are sooo many variables
i'd just take that joint to a mechanic
post Apr 23, 2005 - 9:29 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
mine does the same exact thing. weird.
post Apr 24, 2005 - 12:03 AM
MonsterBOX
Joined Jan 8, '05
From Alabama
buy new plugs they r not even 15 bucks..so do it anyways....get some new wires from ngk or some new toyota wire...check out the distributor make sure it isnt f'd up...and check ur fuel pump/filter...unplug battery for bout 10 mins and hook it back up to let the ecu reprogram
post Apr 24, 2005 - 12:12 AM
idle air sensor ?
post Apr 24, 2005 - 1:26 AM
QUOTE(king_wsk @ Apr 23, 2005 - 5:46 PM)
[right][snapback]276934[/snapback][/right]
start there. replace plugs, cap, rotor, and wires. then report back to us.
post Apr 24, 2005 - 2:02 PM
Newbie
Joined Nov 3, '04
From Colorado
You do know, with manual transmission, the throttle control is more direct. For extreme example, if you are just rolling at 3-5MPH, and suddenly, you floor the accelerator peddal, the car will bounce back and forth. I don't know if that will apply or not.. But something to think about, I guess. Otherwise, good luck. smile.gif
post Apr 24, 2005 - 4:25 PM
Shigexile
Joined Oct 30, '03
From IL
mine usually idle at 700. In my case, the spark wires weren't fit snugly. It still idles at 700 but the motor is more smooth now.
post Apr 24, 2005 - 4:41 PM
darksecret
Joined Mar 9, '05
From Charlotte
You think that maybe it's the A/C compressor kicking in, that will cause the idle to increase.
post Apr 24, 2005 - 7:50 PM
king_wsk
Joined Mar 17, '05
From Northridge, CA
QUOTE(darksecret @ Apr 24, 2005 - 4:41 PM)
[right][snapback]277296[/snapback][/right]
I never run the A/C, so it can't be that. I'm going to spend some time tuesday hopefully and give the car a thorough look over.
post Apr 24, 2005 - 7:52 PM
Could be you have an alternator thats on its way out and when your fans kick on it lowers your RPMs.
post Apr 24, 2005 - 7:54 PM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(playr158 @ Apr 23, 2005 - 11:41 PM)
check (or get new)
[right][snapback]276947[/snapback][/right]
Start cheap replace the fuel filter. Player what does the clutch have to do with anything?
post Apr 24, 2005 - 8:12 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
1000 healthy, thats hi bro mine idles at about 700-800 constant.
Team 6gc 2005
darksecret
Joined Mar 9, '05
From Charlotte
QUOTE(king_wsk @ Apr 24, 2005 - 8:50 PM)
[right][snapback]277386[/snapback][/right]
I don't know if the Celica is the same but on some other vehicles the compressor runs all the time unless the switch is set to floor and dash, my 97 Sierra was that way.
post Apr 24, 2005 - 9:21 PM
king_wsk
Joined Mar 17, '05
From Northridge, CA
QUOTE(darksecret @ Apr 24, 2005 - 8:12 PM)
[right][snapback]277393[/snapback][/right]
I don't think the compressor runs all the time cause I really notice the difference when I do turn on the A/C.
post Apr 24, 2005 - 9:42 PM
darksecret
Joined Mar 9, '05
From Charlotte
It wouldn't make sence anyways you're dropping RPM's instead of gaining, my mistake. Like Drocay said that is high i'm at 700RPM idle also.
post Apr 26, 2005 - 2:19 AM
king_wsk
Joined Mar 17, '05
From Northridge, CA
You're not going to believe this. While installing the modified 90-93 Accord CAI, I noticed that the temp sensor was unplugged!!! Also, while the filter was new (just changed it), the rest of the stock intake system was dirty as hell! I've only driven around less than 10 miles, but I already notice that the engine now idles right around 750 rpms and so far hasn't done any of that lunging.
I don't know if it was the fact that the sensor was unplugged or the intake was super dirty that caused it, but I really don't care now cause it works!!!
Thanks anyways for the suggestions.
This post has been edited by king_wsk: Apr 26, 2005 - 2:44 AM
Lo-Fi Version Time is now: August 24th, 2026 - 10:30 PM
