Apr 25, 2005 - 4:31 PM
Enthusiast ![]() Joined Nov 24, '02 Currently Offline Reputation: 0 (0%) |
The shocks do come with some sort of instruction but as we know the install may involve welding and what not. I dont want to give it to my mechanic and sketch him out telling him this without directions. Is there a specific writeup on how to do this on the celica?
Apr 25, 2005 - 5:34 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
when i installed my konis, all i had to do was cut the rear shocks to where the old shock will slide out.
Apr 25, 2005 - 6:32 PM
just get the bilsteins, and dont deal with cutting or welding! 2 replacement rears and 2 front inserts.
Apr 26, 2005 - 10:51 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
your mech will figure it out. the fronts are easy, so I did them myself. the rears I took my mechanic, he said it was pretty straightforward
Apr 26, 2005 - 12:14 PM
isn't that backwards ghost?
cause the rear are new struts entirely and the fronts are inserts? |
Apr 26, 2005 - 12:43 PM
![]() Enthusiast ![]() ![]() Joined Feb 3, '05 From Portland, OR Currently Offline Reputation: 0 (0%) |
nope the fronts are replacements and the rears you need to cut the top off the stock shock housing and drill a hole in the bottom and the koni's slide in and bolt through the hole
Apr 26, 2005 - 1:02 PM
ok i know thats wrong for a fact
the FRONT is insert the rear is new cause i've already replaced my rears with NEW assembly the whole thing the front i look up and are inserts this is a first time i hear the rear are inserts? |
Apr 26, 2005 - 1:10 PM
maybe the koni site is wrong or maybe they are both inserts, I don't have them on my car so I don't know for sure, but when I was going to buy a set I read the instructions on the install and it said to cut the top off the rear housing and empty them out, then bolt the new koni inserts in.
Apr 26, 2005 - 1:41 PM
maybe they just mean cut the bottoms of the strut and empty old shock insert and insert new. not the rear strut itself.
Apr 26, 2005 - 5:36 PM
QUOTE(playr158 @ Apr 26, 2005 - 1:02 PM) ok i know thats wrong for a fact the FRONT is insert the rear is new cause i've already replaced my rears with NEW assembly the whole thing the front i look up and are inserts this is a first time i hear the rear are inserts? [right][snapback]278353[/snapback][/right] the rear on konis are inserts. you have to cut the top of the orignal shock and pull it out. then you have to drill a hole on the bottom, slide the new insert in, and with the hole you screw the assembly back together. i can try and get a copy of the instructions up soon. edit... found a pic. of the rear struts.
This post has been edited by BLINKYxMUNKEY: Apr 26, 2005 - 8:57 PM -------------------- |
Apr 26, 2005 - 6:58 PM
word.
QUOTE(BLINKYxMUNKEY @ Apr 26, 2005 - 6:36 PM) QUOTE(playr158 @ Apr 26, 2005 - 1:02 PM) ok i know thats wrong for a fact the FRONT is insert the rear is new cause i've already replaced my rears with NEW assembly the whole thing the front i look up and are inserts this is a first time i hear the rear are inserts? [right][snapback]278353[/snapback][/right] the rear on konis are inserts. you have to cut the top of the orignal shock and pull it out. then you have to drill a hole on the bottom, slide the new insert in, and with the hole you screw the assembly back together. i can try and get a copy of the instructions up soon. [right][snapback]278509[/snapback][/right] |
Apr 27, 2005 - 5:45 PM
QUOTE(BLINKYxMUNKEY @ Apr 25, 2005 - 3:34 PM) when i installed my konis, all i had to do was cut the rear shocks to where the old shock will slide out. [right][snapback]277906[/snapback][/right] What? |
Apr 30, 2005 - 12:31 AM
you should post a picture of the old shock insert.
i'd like to see how they look like. |
May 14, 2005 - 4:54 PM
![]() Enthusiast ![]() Joined May 13, '05 From Tipperary Ireland Currently Offline Reputation: 0 (0%) |
QUOTE(AndyST4 @ Apr 26, 2005 - 6:43 PM) nope the fronts are replacements and the rears you need to cut the top off the stock shock housing and drill a hole in the bottom and the koni's slide in and bolt through the hole i [right][snapback]278340[/snapback][/right] i fitted only this week and this is how we done it aswell but the fronts were inserts also -------------------- Cheer's
Mike (,") www.Toyota-irl.com |
May 15, 2005 - 12:50 AM
This post has been edited by playr158: May 15, 2005 - 12:52 AM |
May 16, 2005 - 10:53 AM
Enthusiast ![]() ![]() Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) |
No welding, at least not on my '95 or on any install I've seen pictured. Both front and rear struts are inserts with the Koni setup, only the rear require some cutting and drilling.
BLINKYxMUNKEY's instructions and pics above are accurate. |
| Lo-Fi Version | Time is now: May 18th, 2026 - 1:00 AM |
