> safe boost level
post Apr 25, 2005 - 6:54 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
ok, i have been working on my project 6gen for a few months now, i only drove it around a few times before i laid it up to work on it, and iam pretty much done for now that i got my turbo kit. i was wondering what is a safe boost level to run on the 7afe. its a 1995 with 86K on it. a bunch of people i no run any were from 5-13 on stock internals, but they are all honda or DSM. i was wondering if any of you 7afte guys out their know a safe amount. i herd any were from 5-9.5 but is 10 pushing it?? i just wanna find out before i set the boost controller to high and throw a piston or rod. thanks
Replies (1 - 19)
post Apr 25, 2005 - 7:24 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
I personally wouldn't run anything higher than 10psi on a n/a designed engine. Even then, I'd be warey. Have you considered running water/methanol injection? Would definately help preserve the internals.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Apr 25, 2005 - 7:25 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
yea, but i never done anything like that before. how hard would it be?
post Apr 25, 2005 - 7:57 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(GT4WRC @ Apr 25, 2005 - 4:24 PM)
Gary
[right][snapback]277945[/snapback][/right]
water injection wouldnt really solve the problem of weak internals. it would allow for more boost safely, detonation wise, but the rods are still tiny in a 7afe.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Apr 25, 2005 - 8:01 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
thats my worst problem. i found forged pistons for the 7afe, but cant find rods any were and i know that the 7afe rods arnt the best frown.gif
post Apr 25, 2005 - 8:35 PM
rockstarbass1
Joined Apr 14, '05
From garfield hts. O-HI-O
really only 10 psi in a 7afe?? i dont know for sure but i thought in my probe it was safe to go up to about 15-17 i think???
post Apr 25, 2005 - 8:45 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(rockstarbass1 @ Apr 25, 2005 - 5:35 PM)
[right][snapback]277976[/snapback][/right]
well, technically, it depends on the turbo, but since most 7afte setups have a t3 turbo, it would be best to keep it under 10psi
post Apr 25, 2005 - 8:46 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
that seems kinda high... this is what happens at 13 PSI....
This post has been edited by StreetRacing10PSI: Apr 25, 2005 - 8:51 PM
post Apr 25, 2005 - 9:01 PM
GT4WRC
Joined Mar 17, '05
I think the biggest problem will be heat due to the relatively high compression ratio. Too much heat and stresses on the pistons will increase resulting in catastrophic failure. Most of the time the land rings tend to break up causing the piston to fail. By using water/methanol injection, you can effectively reduce in cylinder temps which reduces the chance of piston failure.
On my rally car I'm building, I plan on upping the CR from 8.5:1 to 9.0:1 to improve off boost throttle response and will be using an Aquamist system to prevent temps from getting too high. I plan on running a max boost of around 18psi (which should easily give me over 300bhp) which is not excessive on an engine with a 'higher' CR.
Rods can be an issue with running too high a boost level. They have a tendancy to take on the shape of a banana if too much boost is thrown at them. If you want reliability, get forged internals and use water injection. Simple belt and braces.
Gary
GT-Four spec list
post Apr 25, 2005 - 9:04 PM
rockstarbass1
Joined Apr 14, '05
my car has 160k miles on it so i dont think i need to worry about turboing it lmao
post Apr 25, 2005 - 9:05 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
do you know were i can get a water cooled piston kit?
post Apr 25, 2005 - 10:24 PM
GT4WRC
Joined Mar 17, '05
QUOTE(StreetRacing10PSI @ Apr 25, 2005 - 9:05 PM)
[right][snapback]277990[/snapback][/right]
It's not a 'water cooled piston kit' as such. A very fine mist of water (and methanol) is injected into the intake stystem post turbo and mixes with the intake charge. The water absorbes heat - though too much and it'll act like a fire extinguisher.
Try looking at www.aquamist.co.uk - they do one of the best kits around and also supply most of the WRC teams. Have one of their kits on my rally car and am planning on fitting one to the FOUR.
This'll give you an idea of what is involved re installation - http://www.220gti.co.nz/water%20injection.htm
Gary
GT-Four spec list
post Apr 25, 2005 - 11:37 PM
popstar
Joined Nov 24, '04
From Moscow, russia
Hmmm looks like a good place to ask ??
my boost gauge is calabrated in kg - cm2 !
can any one translate this in to real money ?
cause i've pushed up to '1.1' !!!!
any ideas, or any one got a good convertion system !!!!?????
thanks
popstar
Life is for living, and you don't get a second chance
Take care now !!
post Apr 25, 2005 - 11:41 PM
946thGenGT
Joined Oct 4, '04
QUOTE(popstar @ Apr 25, 2005 - 10:37 PM)
thanks
popstar
[right][snapback]278095[/snapback][/right]
I'm pretty sure that would be about 15 or 16psi, but I could be wrong because that seems pretty high... http://www.convert-me.com/en/convert/pressure
post Apr 25, 2005 - 11:48 PM
popstar
Joined Nov 24, '04
From Moscow, russia
hmmm that is high.....
i think i need a new boost gauge or get this one checked.......
thanks
Take care now !!
post Apr 25, 2005 - 11:49 PM
boosted_K2
Joined Aug 30, '02
From Michigan
water injection systems are basically a cost effective way to add "octane" to fuel on demand. octane rating is just a rating that states a fuel's resistance to igniting, since water wont ignite, injecting it raises the octane in the mixture when running extremely high boost levels to prevent unwanted detonation, it doesnt exactly "cool" anything per-say.
No but I don't buy it
Cause I'm...
post Apr 26, 2005 - 8:25 AM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
but it is possible to run more boost than right?? snfd if so whats safe on a 7afte, 10??11??
post Apr 26, 2005 - 8:39 AM
id say 8 is safe on a stock internal 7afte
10 is pushing it with stock internals
you also have to realize the rods are the weak point of the 7afe motor
not necissarily the pistons
post Apr 26, 2005 - 8:47 AM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
yes i no, but i cant find forged rods anywere!! frown.gif any ideas??
post Apr 26, 2005 - 9:07 AM
nik
Joined Sep 30, '02
i pushed it to 14psi but ran out of injector in the top end but on stock i would keep it around 10 and i sent you a pm
Lo-Fi Version Time is now: June 26th, 2026 - 5:35 AM
