> in dash dvd.. disableing...... help plz, how to disable cant watvh while driving?
post May 2, 2005 - 2:12 AM
audioOutput
Joined Apr 18, '05
From Temecula, CA
i just installed an in dash dvd (professionally)..
but the guy who installed it said that its illeagle for them to NOT install the safty feature ... the one where you cant watch dvds while driving...
so... i was wondering if any of you guys knew how to disable the feature..
i know it has to do something about grounding a wire out.,.. but how?
any help would be great.. and thanks!!
Replies (1 - 9)
post May 2, 2005 - 4:29 AM
I can't remember, but I think our e-brake setups are negative trigger, meaning the wire under the console that connects to the e-brake gives ground when the e-brake is ground. If that's the case and they tapped into that wire, just ground the wire coming from your head unit. There was a thread about this a while ago I think. A search will find it, and there's probably a lot more information in it.
post May 2, 2005 - 8:06 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
yup on most u can just ground it, check your deck but its most likely that simple.
Team 6gc 2005
post May 3, 2005 - 3:59 PM
forkee
Joined Nov 13, '02
From So Cal
yea i replied to a similar thread a long time ago. i connected that wire to one of the wires going to the clock. i forgot which one though. if you touch the wire to open end (the one that goes into the clock) u could easily find out which one.
post May 3, 2005 - 5:06 PM
Pali_playa
Joined Apr 4, '04
From VA, USA
depens on which headunit, apline u cant just ground, because it looks for a paulsating ground. and you cant 100% for an Avic-N2 because it uses nav to sense when ur drving so it turns off dvd feature. but most yes, you just ground the parking break wire
post May 3, 2005 - 10:51 PM
QUOTE(forkee @ May 3, 2005 - 1:59 PM)
[right][snapback]281983[/snapback][/right]
You could also fry your head unit, which wouldn't be very cool. I would never just randomly touch wires together to find one that works. Always test with a multimeter.
post May 4, 2005 - 1:23 AM
audioOutput
Joined Apr 18, '05
From Temecula, CA
i have the alpine iva-d901 (quite possibly THE best in dash dvd player there is wink.gif )
but neways... yeah... there is a green wire right under my e-brake.. so all i need to do is geound that wire and ill be good to go?.. ill just ground it to the cigarete lighter if thats the case...
edit - when im parked and put the e brake down -- it works , but once i pull it up.. it dosnt..
i think the green wire is the ground
This post has been edited by audioOutput: May 4, 2005 - 1:25 AM
post May 4, 2005 - 5:39 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
I got the cva801 and i use the aftermarket pac module which you can find on ebay
post May 5, 2005 - 1:01 PM
red94celicagt
Joined Jan 28, '05
From Cincinnati, Ohio
hey i am new on here, but i know my fair share of celica info. =) madmods is right, if your dvd player is an alpine, there are manual video bypass switches you can purchase on ebay. They are compatible with all of the CVA, IVA, TME and TMX models. look into them, they are going for about 8 bucks right now.
Speeding is only Illegal...
If you Get Caught
post May 13, 2005 - 9:44 AM
lazer_mjj
Joined May 11, '05
From Bristol, UK
wire the handbrake cable to the negative power supply feed on the harness on the back of the player works fine with mine!
Lo-Fi Version Time is now: September 18th, 2026 - 6:56 PM
