> Beams V VVTLi
post May 13, 2005 - 3:23 PM
Gerry
Joined Apr 3, '03
From Ireland
I have a beams 98 celica but am thinkin of tradin it in for a 99 VVTLi celica with a trd bodykit... what you guys think... Am I mad
Replies (1 - 9)
post May 13, 2005 - 5:08 PM
orvillescelica
your 98 BEAMS should already have VVT-i. So if that 99 is also an SS-II, then it has basically the same BEAMS as your car. So you are basically just swaping for the kit then??
post May 13, 2005 - 5:35 PM
Junior
Joined May 5, '03
From Toronto
don't do it
post May 13, 2005 - 5:40 PM
GeEkBoY
Joined May 17, '03
From Ontario, Canada
YES!!! (you are mad- edit)
-I assume the red top beams...
Keep the sixth gen. if you can find dynos on the two engines you would realize how much better the red top beams is.
This post has been edited by GeEkBoY: May 13, 2005 - 6:42 PM
post May 13, 2005 - 6:00 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
A 99 Celica SSII overseas can be a 7th gen...
post May 13, 2005 - 7:52 PM
kevstir
Joined Jul 5, '03
From Scotland , Uk
on looks alone keep it m8 biggrin.gif , go look in the gen 7 section of celica club uk and see the amount of posts regarding problems , after you have done that check the gen 6 forum and compare , i think u will find that there's a lot more complaints in the Gen 7 section, the gen 7 just isnt put together as good as the gen 5 & 6
Kev
post May 13, 2005 - 8:45 PM
CoSo
Joined Jun 8, '04
From Perth, Australia
I thought the 3S-GE BEAMS VVT-i Celicas had 200 HP while the 7th gen 2zz VVTL-i had 170-odd?
post May 13, 2005 - 10:23 PM
GeEkBoY
Joined May 17, '03
NA 2zz have 180
JDM and UK have 190, I think
Key here is 'usable power' which the 2zz is short of.
post May 14, 2005 - 12:13 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(GeEkBoY @ May 14, 2005 - 3:23 AM)
NA 2zz have 180
[right][snapback]286726[/snapback][/right]
When a car is racing... it doesn't spin at 4000 rpms... 2ZZ has plenty of useable power for performance purposes... An argument like that would say F1 cars are slow because they don't have "useable" power... rolleyes.gif
It's a matter of prefrence. The 7th gen GTS (SS2) is as fast as the Beams 6th gen Celicas in track situations. The beams will be a more friendly driver car.
post May 16, 2005 - 3:34 PM
BlackSTX
Joined May 17, '03
From Florence, KY
Stick with the 6th gen, it's rare and beautiful.
Lo-Fi Version Time is now: May 10th, 2026 - 12:02 PM
