> And it begins, Black or Silver top
post May 19, 2005 - 6:35 PM
Skate4mindgame
Joined Oct 1, '04
From Michigan
Ok so the trans finally blew in celica sooo i decided now would be as good of a time as any to start engine build/swap.
I have decided to go the N/A 4age route more then likely one of the 20v's.
What do you guys think? Ill be completley ripping the engine apart as soon as i get it. Replacing most of the internals.
Replies (1 - 14)
post May 19, 2005 - 6:53 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
id get the black top 20v... its a lot different then what most people think of it of just 5hp more then the silver top. also the black top is MAP based and is easier to tune in my opinion.
post May 19, 2005 - 7:13 PM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
i also heard the silvertop is way over rated. it is actually like 10 hp less than what is advertised. id say go with the blacktop.
post May 19, 2005 - 8:57 PM
Skate4mindgame
Joined Oct 1, '04
From Michigan
QUOTE(rocky2006 @ May 20, 2005 - 12:13 AM)
[right][snapback]289202[/snapback][/right]
Yes the Silvertop is overrated by about 10-15 horsepower.
post May 20, 2005 - 2:45 AM
trdevelopment
Joined Jul 27, '04
From phoenix az
post May 20, 2005 - 9:03 AM
vangSTa_celica
Joined Jul 10, '03
From Appleton,WI
But, according to what I've read, the silvertop handles boost much better.
A Jaws4God Creation...
post May 20, 2005 - 11:57 AM
Skate4mindgame
Joined Oct 1, '04
From Michigan
QUOTE(vangSTa_celica @ May 20, 2005 - 2:03 PM)
[right][snapback]289432[/snapback][/right]
Which really wont matter since i said i was going the N/A route.
post May 20, 2005 - 12:09 PM
nik
Joined Sep 30, '02
you want a really cool 20v black top
get the motor and throw the 7afe blcok under it with some custom rods stock BT pistons
now you have 1.8L n/a blacktop motor
but just a blacktop with 6 speed would be cool also
post May 20, 2005 - 11:32 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Yes, if you are going all n/a, go with either a Blacktop or a 2ZZGE.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post May 20, 2005 - 11:37 PM
Mike
Joined Oct 22, '02
From Toronto
QUOTE(nik @ May 20, 2005 - 10:09 AM)
[right][snapback]289515[/snapback][/right]
you have the best sig ever....ever!
post May 21, 2005 - 1:15 AM
FallenHero
Joined Dec 26, '02
From Alabama
for na, get the black top. The pistons/rods are freakin -a- light, the engine also has higher lift on the cams than the silver top. The ITB's are also larger. Because it is map based, you can remove the restrictive intake plenum, or housing, and run the ITB's with some sort of low restriction intake set up.
I personally would turbo the silvertop.. but that's just me.
post May 21, 2005 - 11:54 AM
Skate4mindgame
Joined Oct 1, '04
From Michigan
Aye i would probably turbo the silvertop as well but i want just a N/A engine... just dont see to many of them on here.
So you think stock pistons rods will be fine in it? I know the aftermarket for the 20v's isnt that great. I was thinking about changing them or boring it slightly over to bump up the compression a bit more.
post May 23, 2005 - 7:13 PM
Mike431635
Joined Jul 20, '04
From Tampa, FL
I'm actually looking into a blacktop swap in my 93 ST right now with the 6spd transmission. That would be one awesome ride, especially with the throttle bodies run open-element with some nice velocity stacks. You can also use the Ford EDIS-4 from the 1.9L Tempo/Tracer coupled with Megasquirt and make some great power with it. If you wanna go NA, that's the best route. You will pay the price though.
If you decide to go silvertop, Jarco is getting an AE101 clip in this week and selling for $1650.
post May 25, 2005 - 3:12 PM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE(Skate4mindgame @ May 21, 2005 - 9:54 AM)
[right][snapback]289985[/snapback][/right]
I came to this discovery a long time ago. Not many N/A cars ehh? there might be a reason. wink.gif
A cheaply turboed 7a will outrun a blacktop 6spd hands down in the straight line. It would have more hp. and torque. In an AutoX match, the drivers would decide.
post May 25, 2005 - 3:49 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(FallenHero @ May 25, 2005 - 8:12 PM)
[right][snapback]291723[/snapback][/right]
I disagree. Based on dyno results of a 7AFTE (around 8-10 psi)... I don't think it can out run the blacktop 20V by much in the 1/4 mile. AE111's have proven overseas to be very formidable, and the blacktop is a much better set-up than a silvertop. It'll be very close. On a circuit, the 7AFTE *might* be able to win... on a closed short track, the 20V will win easily. This is assuming the engines are in the same cars.
Lo-Fi Version Time is now: August 26th, 2026 - 8:47 AM
