> Headlight plastic, doggy, help!
post Jun 3, 2005 - 6:11 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
my passenger side low beam has all three plastic brakcets broken. i remember seeing one of doggy's posts where he fixed the plastic with something. almost looked like he blended it with something. anyone know what it was. doggy, help me out. thanks!
Replies (1 - 3)
post Jun 5, 2005 - 2:28 PM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
I used soldering gun to blend the plastic together, it is easyer if you have some same kind of plastc around, so you just cut the piece of it, and using soldering gun glue/blend everything together..
As for making them even stronger (the mounts) i sometime use some thin metal wire, and blend it in the mounts with soldering gun.
<<<<<< DCw / JDMart >>>>>>>
post Jun 5, 2005 - 11:03 PM
ghostdog
From ny to philly
doggy do you know what type of plastic it is? I know that different types won't bond with each other. abs maybe?
post Jun 6, 2005 - 12:26 AM
doGGy
Joined Oct 28, '02
I dont know how it is called in english.... But the plastic that the headlights are made of does glue and solder very very good. As for different types of plastic not glueing together - yes, some types may never glue to other types of plastics..
QUOTE(ghostdog @ Jun 5, 2005 - 9:03 PM)
[right][snapback]295331[/snapback][/right]
Lo-Fi Version Time is now: September 19th, 2026 - 4:24 AM
