Jun 8, 2005 - 10:20 PM
Enthusiast ![]() ![]() Joined Oct 19, '02 From Spring Valley, NY Currently Offline Reputation: 1 (100%) |
spark plugs, wires, cap and rotor
flush coolant and power steering fluid, transmission oil change timing belt and tensioner replace fuel filter, pcv valve, valve cover gasket do i need to replace the fuel injectors?? how bout the water pump?? thanx alex |
Jun 8, 2005 - 10:32 PM
do the water pump and gasket if you do the timing blet. also a new thermostat .
fuel injectors normally dont go bad when they are still in a running car, but you can mail them out to a few places that will clean and balance them for you if you are really worried. This post has been edited by lagos: Jun 8, 2005 - 10:33 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 9, 2005 - 12:01 AM
this is gonna be my first major tune up...original belt since i got the car at 29K and now its at 117K...i've searched on this forums and some people have done it 3 times within 100,000 miles...guess it really depends on how hard u push ur car...
which gasket?? the head gasket?? just makin' sure... |
Jun 9, 2005 - 12:03 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
Brake fluid flush while you're at it, fuel injector service.
Valve cover gasket isn't necessary at 100,000 miles, though you can. Clean the intake. |
Jun 9, 2005 - 12:08 AM
not head gasket, i meant a new gasket for the new water pump. you can do your valve cover gasket if you think its leaking oil.
| Lo-Fi Version | Time is now: September 1st, 2026 - 12:31 AM |
