> Automatic Transmission, Shift parameters
post Jul 2, 2005 - 10:25 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
What information is needed by the ECU to decide when to shift?
So far I assume that these are definitely needed:
Throttle Position Signal
Tach signal
Speed Sensor
coolant temperature (for limiting rpm while engine is cold)
Can anyone think of anything else that would be needed by the ECU to operate the transmission.
Replies (1 - 12)
post Jul 3, 2005 - 3:55 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
i dont know anything about mechanics, but im curious as of why you need that information. dont mean to be nosy, just curious. smile.gif
post Jul 3, 2005 - 8:00 AM
Hanyo
Joined Aug 16, '03
From Bay area
let me guess paddle shifts!?
it also shifts the tranny by comparing the throttle position and rpm to calculate engine load. If the engine load is higher the tranny will shift later.
post Jul 3, 2005 - 8:50 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Well I'll be mating a 3SGTE to an auto transmission and I was hoping to let the stock 5SFE ECU control the transmission. The paddle shift idea would be cool if it didn't take so long for the transmission to change gears when the next gear was selected.
This post has been edited by WannabeGT4: Jul 3, 2005 - 8:51 AM
post Jul 6, 2005 - 4:58 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Any other input on this?
post Jul 6, 2005 - 6:33 PM
FallenHero
Joined Dec 26, '02
From Alabama
www.levelten.com
post Jul 6, 2005 - 9:05 PM
SoundSlut_dotcom
Joined Feb 16, '03
mr2 tranny i hope?
post Jul 6, 2005 - 10:15 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(SoundSlut_dotcom @ Jul 6, 2005 - 9:05 PM)
mr2 tranny i hope?
[right][snapback]309346[/snapback][/right]
I don't know why an MR2 auto trans would be any stronger than a 6gc auto trans. They were both mated to the 5SFE.
post Jul 6, 2005 - 10:16 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(FallenHero @ Jul 6, 2005 - 6:33 PM)
www.levelten.com
[right][snapback]309289[/snapback][/right]
Thanks. I was looking for that site the other day and couldn't find it.
post Jul 7, 2005 - 9:26 AM
_rz_
Joined Jul 20, '04
From Russia, Moscow
just get a caldina auto trans
as far as I researched there is no chance to mate a celica auto trans and a 3s-gte
post Jul 7, 2005 - 9:54 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(_rz_ @ Jul 7, 2005 - 9:26 AM)
[right][snapback]309580[/snapback][/right]
Caldina = 4WD
Celica GT = FWD
I already have an auto trans.
As far as your research is concerned, what led you to that conclusion? If it's the lack of an auto ECU for the 3SGTE I've already overcome that issue. I'll be running a standalone for the 3S and the stock ECU for the trans.
post Oct 11, 2006 - 10:49 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
QUOTE(WannabeGT4 @ Jul 7, 2005 - 7:54 AM) [snapback]309589[/snapback]
Caldina = 4WD
Celica GT = FWD
why not AWD conversion with the AWD autox? that would be something NEVER EVER EVER done before? then upgrade the valve body, and those were tiptronic so your paddle shifter idea comes into play. the ULTIMATE auto swap. atleast an idea to play with i understand you want to get this auto in and working. i can relate kindasad.gif
post Oct 12, 2006 - 12:47 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(celicast3sgte @ Oct 11, 2006 - 10:49 PM) [snapback]490548[/snapback]
Caldina = 4WD
Celica GT = FWD
How about he puts a V8 in there while he's at it?
Lo-Fi Version Time is now: September 20th, 2026 - 11:58 PM
